Hitachi 4TEDT41 BLACK LINES
I have been searching for where to look on the F5 board that is located in the center lower part of the tv for broken solder joints. Could you give me some more information on where to look or some pictures would be great. thanks. Bryan.
    Scholar:
  • 73 Answers
The solder joints aren't actually on a board. They are on the orange ribbons connecting the screen to the circuit board on the bottom of the set. It's a bit labor intensive to dismantle the TV down to access all of the ribbons as there is a 2 (ish) inch ribbon every 4 inches or so along the bottom, two of them are behind the screen braces. Depending on where the lines are, you'll have to remove different parts. Like building legos, just pay attention to where you got what and you'll be fine. The lines will coincide with the ribbon in the same area. once you have removed the braces, which you may not have to do depending on where the black lines are, there is a clear plastic shield across the bottom covering them. Don't be afraid to make a cut in this shield to expose the ribbons. Don't cut the shield off, just a vertical cut to get access. If I remember right, The ribbons unclip from the board by raising the dark brown tension clip on each latch. Be carefull with these they are very easy to break and d@mn near impossible to fix once broken.
Fold the ribbon down and back and you'll see the 100 chips on each ribbon. The solder joints holding those in place are what need touching up. With a 15 watt iron, NO LARGER, and a little tiny bit of solder, freshen up each joint on both sides of the 100 chip. Don't bother with the little one above them. Don't leave the iron on the chips for more than 2 seconds. If you want to prevent this from happening again, touch up each chip along all the ribbons. Let me know if you need more help. Happy to assist in any way I can.
Axle
Posted on Dec 12, 2008
  • Axle80
    Axle80 Dec 12, 2008
    clarification, there are 4 chips per ribbon, not a hundred. The chips you are looking for are marked with '100'.
Horizontal lines
Contact the authorized service center for Hitachi. Never do any more adjustments. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 25, 2014 | Hitachi P50H401 50 in. Plasma HDTV
My tv only show black and white lines, it shows no picture but the lines
The main digital processor board should be troubleshooted. The work is a skilled one, that a user cannot locate the exact fault point with these boards. Contact any experienced service technician. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Toshiba 62HM95 62" DLP HDTV
My hitachi plasma 1080 tv has black horizontal lines on the top half of the screen
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there. Faults to Plasma TVs are described in detail there. Check it. Just see, almost all Plasmas are built on same type chassis and board configuration, so the fault to these sets too will be almost the same in nature.
Oct 24, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Where can i get a power board for hitachi tv 42pd8a10
Get the part number from the power board.
Search for the power board using, the part number instead of the TV model#.
www.aaatvservice.com
Jan 26, 2012 | Hitachi 42 in. Plasma TV
Has black horizontal lines
Let me try and help you out mc_industria,
The black lines are more likely being caused by a malfunction in the circuit boards in the TV. I would recommend calling Hitachi and speaking to them about the problem. You can also have a TV repair technician to attempt to fix the problem. This is not a problem that will go away on its own, it will require some work.
Hope this helps.
Jan 25, 2011 | Hitachi P50V702 50 in. Plasma HDTV
My toshiba S300m has a VGA socket and no S cable socket. I want to connect the Tosh. with my TV. Problem is that the TV is an older one and has a S video (female) and it also has three (Yellow, white,...
try to lower your video/screen resolution down to what your older tv can take as an input. (try 800x600 or lower) first if that does not work search on eBay for
VGA SVGA TO S-Video 3 RCA Composite AV TV Out Converter Adapter Cable PC Cord
Jun 04, 2017 | Toshiba Satellite Pro S300M-S2403 Laptop
Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Jun 29, 2010 | Hitachi P50H401 50 in. Plasma HDTV
When you turn the TV on the screen splits in two,
it sounds like one of your buffer boards are going bad. these are the boards that help put the picture on the screen. there are 2 boards an upper and a lower board. if you remove one and turn the tv on you will get half a screen. see then if you get the lines. please leave rating after you check.
May 10, 2010 | Hitachi P50H401 50 in. Plasma HDTV
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
