Question about Toshiba Satellite 1415-S173 Notebook
Toshiba Satallite 1415 wont boot
I just took apart my Toshiba Satellite 1415 laptop to clean up the fan because it was starting to make noises, and I also wanted to see how easy it would be to replace. I then reassambled everything. I took careful note when taking it apart to put everything back together correctly. I then turned it on and it will not boot. It gave me a message that my Windows/System/drivers folder could not be found and then nothing. Should I try a boot CD and How do I get into CMOS on this model (1415-S173)?
  • faith_aurora Dec 05, 2008
    I actually went into CMOS and it is reading the HDD, and I got the same message again. Now I know exactly what it says. It said that windows could not start, becuase it could not find the System32\Drivers\pci.sys file. Then it directed me to use my original Setup CD to try to repair it, and to do this I needed to press "r" when starting up the system. Why would this be?
    Scholar:
  • 37 Answers
Sounds like maybe the hard drive is not hooked up or not hooked correctly. Tey unhooking it and re hooking it back up.
If it worked before but not now it has to be somethign is not hooked ack up correctly and a cd will not help.
If Its not the hard drive I would suggest taking it back apart to the point you had it before and reasembling it again but make sure all connections are tight, especially the ones where you slide the flat wire in and then lock it.
It has to be a loos connection some where.
that or the timing of the failure is just coincedental with the disasembly and one has nothing to do with the other.  If thats the case then you have a different problem.
If it is just a fluke and you just have failure I would suggest downloading a program you can install to cd like windows live and then boot to the cd.  once booted to cd you can access the hard drive and fix any problems with directory structure.
Posted on Dec 05, 2008
  • George McCollum Dec 05, 2008
    If I had to wger a guess.  I would say it was a fluke it happened at the same time.
    try booting into safe mode, I think it is either f5 or f8 while rebooting, then click safe mode with network support.  This should load windows safe mode.
    now find a good working copy of the file, usually just take from another machine running same opperating system.  Then copy it to the computer rename the old file (it can be found in the system 32 folder in windows directoy. I usually rename to pci.old then copy new file to same location.  Then reboot.  if it works delet the old one but if it doesnt then reboot into safe mode again and delet new one and rename old one back to original file name.
    hope this helps
Toshia PSAF3U-0NR00V wont stay on turns on and off
check for a damaged power connection to the motherboard.
for mine it was the power connection, brought a new one took it apart and soldered it, been working ever since
Jul 20, 2012 | Toshiba Satellite A205-S5804 Notebook
I am trying to figure out how to boot from a usb drive on my toshiba satellite 1415-s105
1. Press F12 key while the Toshiba splash screen is on, this will bring up the boot options menu.
2. Immediately after pressing the power-on button, press the U key.
For more information on boot options for Toshiba:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?soid=403623
Jul 21, 2011 | Toshiba Satellite 1415-S105 Notebook
Laptop wont run on start up a black screen just pops up
restart as it starts up press f8 and see if it will go to boot options and select start last known configeration
Jan 23, 2011 | Toshiba Satellite 1415-S173 Notebook
Won\t boot up and dont have start up disks
please give more details about the problem, like error messages, color of ecreen, beeps, etc.!
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
Toshiba 1415-S173 overheats and cripples the cpu. how to fix this problem?
Assuming there is a fan / heatsink above the CPU, is the fan working? If not, replace the fan. If there's no fan (or if it works), maybe try removing the heatsink and re-setting it with new thermal compound. Apart from that, clean all airways of dust and ensure that when you're using it that the vents are uncovered.
Sep 29, 2009 | Toshiba Satellite 1415-S173 Notebook
Boot via LAN
The wake up on LAN is usually setup from the BIOS configuration.
If you BIOS doesn't have this option then it is not possible.
Apr 28, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1415-S173 Notebook Logo
113 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
