Question about Cobra 29 LTD CB Radio
Cobra 29 LTD Classic not transmitting or receiving
I just bought and installed a Cobra 29 LTD Classic with a Firestik 2 (4') antenna on a 99 Dodge 2500. I mounted the antenna on my alunimum toolbox on the passenger side. I did ground the toolbox to the pickup. The radio turns on fine and everything apperas to be fine but the ANT light does not light up. I used good coax cable and it is not grounded out anywhere. I cant transmit or receive, I can hear nothing at all. Is this a antenna mounting problem? Thanks for any information.
  • Benji Moore May 11, 2010
    have you checked the mic? If thereis a wire broke in the mic it will cause this issue.
As I understand from a tech friend of mine, most truck beds are not grounded well enough. Perhaps you could borrow/purchase a magnet mount antenna and locate it on the roof, for testing. Then you would have it narrowed down to the location.
Posted on Jan 07, 2009
Cobra 29 ltd classic year 2004. rf gain problems.
Put SWR meter between your antenna and output, test wave length receive/transmit, might need a ground plane or center loaded stick.
Could be transceiver relay, try clicking mic fast, it should click out as fast as you key the mic.
Oct 26, 2016 | Cobra Radio Communications
When it's dry, I can't transmit, but when my antennas get wet,transmission doubles, WHY????
Hi John:
Try checking where the antenna is connected to the cable.
It may be corroded and you're not getting continuity unless it is wet.
Jan 08, 2016 | Cobra 29-LTD 29 LTD Classic CB Radio
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
Cobra 29 now Ltd classic Cobra 29 nw.ltd classic receives not well but does not transmit don't even move the swr./power meter any ideas
High SWR on antenna system.. may have mess up your RF final transistors. if you were talking on it for a long time. have someone check the SWR on the antenna system... should be a FREE service.
Jul 13, 2014 | Radio Communications
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
HELLO STAN FIRST HAS THE RADIO BEEN PEAKED AND TUNED? SECOND IS THE INTERIOR LIGHT IN YOUR PICK UP RIGHT BELOW YOUR ANTENNA,IF SO YOU HAVE A PROBLEM BUT EASY FIX THE WIRING GOING TO THE LIGHT ACTS LIKE AN EXTRA ANTENNA CAUSING YOUR ANTENNA TO RESONATE TO YOUR RADIO CAUSING THE A W I LIGHT TO COME ON MOVE YOU ANTENNA BACK A LITTLE FUTHER AND SHOULD BE GOODif you want to get a bettter antenna get a willson 500 mag mount far better
I have a new cobra 148 with ssb, about 6 months old, while i was away there was a storm, now the radio doesnt work , recieve or transmit, i also have a cobra 29 ltd that wont transmit but it will recieve....
make sure the mic is good. If for some reason the mic went bad, it will not receive or transmit.
As for the one with no receive, it most likely needs a new final.
If lightning hit your antron, it would be in pieces.
Aug 02, 2010 | Cobra 148 GTL 120-Channels Base CB Radio
Bought a new cobra 29, need antenna advice
Firestik Dual CB Antenna Kit This is a most popular dual antenna kit and one we HIGHLY recommend! It contains everything you need and features premium USA-made components from Firestik. The included FS CB antennas are our best-selling antennas and ensure you'll receive maximum transmit and receive performance. Designed for the elements, the stainless steel springs and mounts are rust- and weather-resistant. The included three-way mounts -- the most popular style we carry-- offer numerous mounting possibilities.
Dec 22, 2009 | Cobra 29 LTD CB Radio
ant. light should only come on if you have a high vswr a bad thing did you check that cb/pa switch is set to cb check your swr this is not a good place to mount ant. as it is close to metal of back of cab
Dec 20, 2008 | Cobra 29 LTD CB Radio
I have just bought a cobra 29 ltd classic with a scanner ant and it worked befor on the turck it was on but now that iv installed it on my truck im not able to talk to other nor hear them
sounds like a mic problem if a wire is broken in the mic it will not let you receive or transmit common..or not to common an audio chip...
Aug 17, 2008 | Cobra 29 LTD CB Radio
Cobra 29 LTD CB Radio Logo
579 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
