Hi I have a bluetooth V512 - it worked fine till now but today I cannot get it to stay on and it does no connect with my blackberry
    Genius:
  • 1,224 Answers
Ok heres the solution completly remove bt. from black berry and go threw a complete setup again
when setting up bb. looking for bt. hold bt. power button down till bb. recognizes it then it will ask for security code 0000 this will set you back up with your bt. again
Posted on Dec 06, 2008
Monster clarity does not work wired
Mine wouldn't either. Now I have paired it with the Bluetooth and it installed something (drivers?), and now it works. So, now how do I know if it is always connecting Bluetooth or wired? I connected the wire and it is still working, so now how do know if I really need the wire or not???
Oct 24, 2012 | Monster Clarity Hd Precision Micro...
How do I connect my blackberry cel phone to my bluetooth ce0678
Hi, you can use this instruction to pair your blue tooth with your cell phone:
Instructions
Pair Your Blackberry with a Bluetooth Headset
Turn on Bluetooth headset and Blackberry hand-held.
Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.
Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.
Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.
Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
Use your Bluetooth Headset with your Blackberry
Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the handheld.
Tips & Warnings
Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Good luck to you..
Feb 01, 2011 | Cell Phones
Hi there I have a blackberry bold 9700 and stoped work today appear in the screen jvm error 102 ! what should i do ?
To fix that error, download Blackberry Desktop then connect your phone to computer. In BB Desktop manager select Device Software Update and wait till your software will be updated. You`ll need an active internet connection and pacience. No setting or data from the phone will be lost if the update will be succesful.
Nov 02, 2010 | Cell Phones
I want to pair with another device, a blackberry curve
I have a Blackberry curve and i use this headset. You just hold in the key to your bluetooth till it stays solid blue light, then go on your blackberry under "options" then "bluetooth" then search or add new device. it will search it, pascode is "0000" should load up then. then everytime u put ur bluetooth on and hit the button to turn it on ur blackberry will pop up and ask if you want to use it, just hit yes and your good to go.
Mike
Jun 12, 2009 | Motorola Mobility H300 Wireless Headset
Won't stay connected.
check the batteries on the BT headset
May 15, 2009 | Motorola Mobility H700 Wireless Headset
My Razr phone 'unable to connect' to blackberry 8310 bluetooth
you have to hold down the power icon till it flashes red and blue then its ready to connect, then select your search settings from your razr. it should find it and ask you for a code. its usually 0000
Apr 15, 2009 | Motorola Mobility RAZR V3
Bluetooth, and my blackberry
Check out the updated Bluetooth firmware specially for Blackberry devices on the Pioneer website.
Mar 28, 2009 | Pioneer AVIC-F700BT Car GPS Receiver
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Bluetooth wont work
Goto:
spanner - wheel click!
bluetooth -wheel click!
bluetooth disabled - wheel click!
Enable bluetooth -wheel click!
Paired devices
*EMPTY*
- wheel click!
Add device - wheel click!
after the search select the device you wish to connect to...& contiue to follow the on screen prompts & pairing instructions.
Dec 18, 2007 | RIM BlackBerry 7290
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
