My Porsche 911 Carrera 2002, go wet from heavy rain, it's making a strange sound, like rain hitting the sides of the doors, is the Engine immobilizer burnt, had about half an inch of water, under drivers seat. The car started, we dried it out, but now the car will not start. Checked fuses, all are in working order. The rain sound is gone, it now has a humming sound instead. I had to disconnect the battery to stop this sound, now I think it's the electronic chassis control module, how to know, before I order the part. Tks.
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
SOURCE: Malfuntioning driver's side power window upon opening door lever.
get it to the dealer asap.
you definitely need to take apart the door. There's something not right inside.
SOURCE: Porsche carrera 911 1999 3.6 overheating problem!!!
either the expansion tank is just cracked or there is a head gasket problem.
SOURCE: Porsche 2000 911 Carrera. Key fob problem
each vehicle is different put the key in the ign. turn key on press door lock/unlock at the same timehold button for 10 sec see if any lights on the dash inst. panel blink if they do that means that the key fob was programmed to your vehicle i recommend a new key fob this will give you definative instructions on how to reprogram your fob
