Question about Copystar CS-1820 Copier
SERVICE ERROR c7980
One of my customer is having a error message appear on the display of a Copystar CS 1820 is there anything I can do to resolve the problem?
  • Keith Deininger
    Keith Deininger May 11, 2010
    Could you please provide some more information as to what the error message is?
    I was a Systems and Technical Sales Engineer for Kyocera-Mita America the parent company who manufacturers this model of copier for more than 6 years. So if you can give me some more information I can point you in the right direction.
    Cheers,
    Keith
    Sniper:
  • 66 Answers
The errorcode comes up when the waste toner is full.
Unfortunately the waste toner collection is in the process unit.
You will have to replace the whole cartidge.
Posted on Dec 14, 2008
I just was replace the cartidge... Thanks
Cambie el cartucho. Gracias
Posted on Apr 20, 2009
Waste toner full and now message error occured C7980 call service person
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera Copystar CS-1820 Black and White...
Se produjo un error llamar al tecnico C7980
On the screen of my KM 1820 copier Kyosera get the message "An error occurred calling a technician" and C 7980
how I can fix this error?
Sep 03, 2010 | Kyocera Copystar CS-1820 Black and White...
The printer shows "Call service person" C7980. What is the problem and how can it be corrected?
this a drum unit related problem. empty the waste toner and the error will reset automatically
Aug 27, 2010 | Kyocera Copystar CS-1820 Black and White...
What is error code c7980
this is drum related error. empty waste toner from the drum unit
Aug 20, 2010 | Kyocera Copystar CS-1820 Black and White...
On the copystar 1815 I have an error message that says 'error occurred call service person'. On the bottom of the screen it reads 'C6400". I can not clear it. Help!
when machine is on hold down stop key, start, left exposure. release them and press start. display will show U000. self status. key in 163 and press start twice
Jul 31, 2010 | Copystar CS-1820 Copier
Clearing code c7980
email me at low_toner @yahoo.com indicate your location
Aug 12, 2009 | Copystar CS-1820 Copier
What is code c7980 waste toner is full???
C7980, Defective waste toner sensor or engine board. Try this, shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be soved, replace the process unit. After replacing the proces sunit, turn the power switch off then on. If the problem cannot be solved, replace the waste toner sensor or the engine board.
Aug 03, 2009 | Kyocera Copystar CS-1820 Black and White...
ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
May 12, 2009 | Copystar CS-1820 Copier
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
682 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
