I just hooked up my old amplifier to my turntable and started playing some vinyl. I'm getting an incredibly annoying static sound through the headphones I'm listening through, and I'm positive it's not the headphones. The static increases as the volume increases, and is very present. If I turn the amplifier to the FM setting, the static goes away. Any solutions would be INCREDIBLY appreciated. Thanks so much!
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Do as the first answer states. Make certain that the audio cables for the turntable are not laying over or close to any of the power cords. If you still have the problem, then the Phono amp circuit board in the receiver is going out. You can buy a external Phono pre-amp and plug it into the AUX input on the receiver.
Posted on Jan 09, 2015
    Problem Solver:
  • 8 Answers
Make sure the ground wire from the turntable (they all have one) is grounded to the amp, also the turntable has to be connected to the phono input on the amp. Turntable cant connect to cd or aux. Only phono. Also check to see if there is dust and dirt built up on the needle. clean if needed. most likely a grounding issue
Posted on Dec 05, 2008
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
I have a JVC turntable (AL-A155TN/AL-A155TNX). I haven't used it in about ten years. I hooked it up today. I played four records on it. Two were fine. The other two, however, started off fine
The only thing that might cause something like that is a build up of static. You can buy anti-static products for records and turntables. I tend to use an anti-static spray which also cleans the records.
Jan 14, 2013 | JVC Audio Players & Recorders
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
Hooked it up but sound is very low. Has a ground
Didi you try to change the middle. that was what was wrong with mine
Jan 13, 2010 | Audio Players & Recorders
Why can't I hear any sound when I record from my turntable conver
hi, you need first a pre amp phono or mixer before you patch into the computer to amplified signal in to your vinyl..
Jul 03, 2009 | Audio Technica AT-LP2D Turntable
Can a turntable be hooked up to this receiver?
The Aux function is not meant for that purpose.The turntables/Record Players being way too old,now a days the amplifiers do not come with PHONO function that was specially used for playing Records/For turntables. Check if u have a phono function in your amplifier and if not then buy another amplifier with Phono function coz you need a ground wire [that comes out from the turn table] also to be attached to the amplifier and then only you can get a proper sound.
Feb 28, 2009 | Yamaha HTR-5440 Receiver
Question on Bose 3-2-1
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose)  to heard and listen to your old vinyl.. mk2 batallion.....
Feb 24, 2009 | Bose 3·2·1 II System
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Nov 28, 2008 | ION Audio Vinyl Recording Turntable
Annoying crunching sound devleloped during recording
It sounds like the same problem I had. I solved it by keeping the stylus free of dust by brushing it frequently with a soft camel hair brush..
Oct 22, 2008 | ION Audio iTTUSB Turntable
203 people viewed this question
 Grubhead
Grubhead
