Question about Dell 5310n Laser Printer
I will print a fax or another file, and instead of printing out the whole document the printer will print some of the pages then spit out 5-20 pages of code. I will have to try printing things maybe 2-4 separate times to get all the pages I need printed
  • 1 more comment
  • alex_illium Dec 05, 2008
    the information that shows up about my printer is
    dell laster printer 5310n PS3, how would i find the driver?
    Thank you very much
  • Ryan Churchill
    Ryan Churchill May 11, 2010
    What is the printer model? What driver are you using?
  • 120 Answers
Your drivers for the printer are here:
http://driverzone.com/device.php?id=72846
Download them, install them and reboot... you should be fine after that.
Hope this helps... and have a good weekend.
Posted on Dec 05, 2008
  • Ryan Churchill
    Ryan Churchill Dec 05, 2008
    You are very welcome.
    Sergeant:
  • 236 Answers
I agree with Democritus, it sounds like a driver issue. Check for a new driver for your printer.
  • Dan
    Dan Dec 05, 2008
    Right-click you printer and go to properties.
    Advance Setting should give you driver info
    You can get new Dell drivers here
Xp word 2002 will only print first page of 4 page document
Be sure to select PRINT ALL instead of PRINT CURRENT PAGE
Jan 22, 2013 | Office Equipment & Supplies
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
MX310 - faxes in memory. Cartridges have been replaced. Error of low ink remains. What is the key sequence to retrieve these faxes?
Press Fax then Menu. You should see Fax Settings across the top row. Use the left/right arrows to select Memory Reference and press OK. Again use the left/right arrows to select Print Document and press OK. Select the transaction (RX) number of the fax you want to print (received faxes start at 5001) and press OK. Then choose whether you want the first page or the entire fax (yes to first page only or no for the entire fax) and press OK. To print additional faxes repeat from the Select RX number. Print the Memory List to find out which fax is which (from the list that you see under Print Document.
Then you can delete these by selecting Delete Document instead of Print Document in the above directions. Then press OK followed by Yes or No for deleting the document.
Finally press Stop/Reset to leave the menu.
I hope this helps.
Sep 24, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer has started spitting out one clean page for every page that is being printed. That is, if I have a two-page document to be printed, it spits out four pages, two pages without anything on them, and...
Go to START, Printer & Faxes, right click your printer and select properties. Under the advanced tab, click seperator page, delete whatever is in the box and click OK. This should stop the blank pages from printing.
Hope this helps
-samson39
Jul 26, 2009 | HP Photosmart C7280 Printer
I wanted one paper printed instead of one i have a whole pile of papers how do i stop same documents printing
Open "File"
Open "Print"
Goto "Print range"
Click on "Pages"
In the first box enter the number of the page you want to print
In the second box enter the number of copies you want.
If you want only 1 copy enter 1 in both of the boxes..
Hope this helps
Apr 10, 2009 | Canon imageCLASS MF8170C All-In-One Laser...
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Not printing whole page
Could be as simply as the right print margin in the application you are using. Try printing a test page by right-clicking on the printer in Printers and Faxes in Control Panel and select Properties. If the test page prints ok then check the margins in the application you are using - usually File>Page Setup. The right margin could be set to 5.0 in instead of 0.5 in.
Dec 15, 2008 | Lexmark X2600 InkJet Printer
Epson Stylus C42
Click on start, control panel then double-click printers and faxes. Double click the printer icon and you will see the printer queue. Click on Printers then Cancel All Documents. When all documents are gone from the print queue, restart your computer and switch your printer on. Click on start, control panel then double-click printers and faxes. Right click the printer icon and click on Properties. Click on Test Print. Check the print is OK. If not, report back.
Sep 23, 2008 | Epson Stylus C86 InkJet Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Dell 5310n Laser Printer Logo
43 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
