Question about Cooktops
Brand new bosch pke691e20e ceramic hob trips 50amp mcb
The 50amp mcb trips when switched on the circuit has a bosch oven rated at 4400 and the hob is rated at 6600 the oven is fine but the hob trips on its own and with the oven 11000/230=47.8amps
  • s_drayton Dec 07, 2008
    thanks for your help, managed to get hold of the sparky and he came round on sun morning and we proved that is the brand new bosch hob which has to go back, great hey
    cheers anyway
  • 334 Answers
You have a short to ground somewhere.
Was there a new cord installed on it or did the cord come already installed?
It could have been wired wrong causing a short to ground. there could be another wire touching the cabinet, a wire pinched by the cabinet.
You may have to trace down every wire with a continuity meter to find it, but its probably fairly obviose.
I'd start at the cord.
First try this, unplug the cord, turn the breaker back on just to make sure the problem is indeed in the unit not the receptacle or panel box.
If the breaker stays on, you know its in the unit.
Posted on Dec 06, 2008
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
I have broken the glass on my induction cooker
ENr is on rating plate on bottom of hob. The Ceramic top is easy to replace, it is held on by 3 pozi screws on each side (12 altogether) and just sits on the main electrical parts, obviously the unit should be isolated from main before you remove the top. Part can be ordered using the link
http://www.bosch-home.co.uk/store/spareparts/search
Mar 16, 2013 | Bosch Cooktops
Hi I have a Samsung ceramic hob that when I have the oven on and cooking veg in saucepans it cuts out randomly displaying SE flashing I'm guessing its overheating but how can I fix this ? It makes
An SE error message on the display of a Samsung ceramic hob means the control panel sensor has been on for too long.
There are a few reasons why the sensor could be saying it's been on for too long:
  • Touching the key area for more than 10 seconds.
  • Leaving a wet cloth on the touch key area.
  • Spilling a liquid on the key area.
  • By touching 2 or more keys together. All of these can be fixed by turning the hob power off at the wall, then back on again.
Jan 30, 2018 | Cooktops
My soup spilled over on to my whirlpool ceran cooktop and i cant get the stains off. Is there a way to do it?
Is this a ceramic hob? If it is, you will need a ceramic hob cleaner (john lewis does one) OR Astonish oven/pan cleaner, a non-scratch washing-up sponge and a fair amount of elbow grease. This works for me.
Oct 05, 2009 | Whirlpool RCS3014 Electric Cooktop
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Cooktops Logo
388 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
