Question about HP Televison & Video
Sony model 51-ws510, Picture is drawn in from top to bottom in the middle of the screen (keystone) all images are on the screen but distorted. I think it might be the high voltage block assy, but before ordering it I need a pro's view on the problem. The sound is ok. Thanks, gary johnson garydj10@gmail.com
  • garydj10 Dec 08, 2008
    Here is an image of the screen, hope this helps diagonse the problem.
    Thanks,
    gary
  • garydj10 Dec 10, 2008
    Tbanks, the serial number is 8733955. Should I order the service manual for the set before replacing the ic's? I have looked at the boards from the back but couldn't identify the ic's visually. As I look at the set from the back I see 3 boards, the vertical one where the power comes in, and two large boards laying flat. I do appreciate the assistance. Thanks again, Gary
    Problem Solver:
  • 5 Answers
No this is a convergence issue. Try auto convergence if this doesnt work. Try manual convergence. If that doesnt work then its your IC chips.
Posted on Feb 27, 2012
  • 10,594 Answers
It doesn't look high voltage block problem.
Can you post here snap of TV showing problem ?
Posted on Dec 05, 2008
  • Shahid Electronics
    Shahid Electronics Dec 09, 2008
    Thanks for posting picture and it really helped to understand the tv problem.
    It is failure of convergence out ICs and if you have little experience of Tv repair and solder work, you can replace these ICs.
    8-749-019-08 IC STK392-560 Quantity 02
    Available in Part Store and price is approx $33.42 each
    And if you don't wish to do it yourself, you can replace complete board.
    A-1302-708-A D BOARD, COMPLETE
    available in Part Store and price is approx $288.42
    !! IMPORTANT !! Before order D Board, let me know serial number of tv to check exact D Board part number.
    Shahid Electronics Dec 10, 2008
    I think it would be nice if you get related service manual from any online part store.
    service manual would help you to find part location, board location ect.
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
Picture curveing down in the middle from the top and curveing up in the middle from the bottom. It also has double and triple colors/images.
your covergence curcitshave failed . there is a high chance that the stk- chips will need to be replaced. at our shop such a repair averages about 150. there may also be some micro fuses that will blow when these chips blow
Oct 22, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence, picture is warped on the sides, double images or ghosts, clear in middle
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2010 | Sony KP-51WS520 51" Rear Projection...
SONY kp-51ws510 rear projection tv. recently it started showing a rainbow on the left top corner and middle bottom of the screen. what might be the problem? can it be fixed? for how much?
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
You can see some examples and find a fix here...
Jan 20, 2010 | Sony KP-51WS510 51" Rear Projection...
My picture slants in towards the top from bottom
The issue has to do with something called "Keystone". This allows you to set the projector at an angle and project on an angle. When you set the projector on a flat surface, you would need to adjust the keystone to get rid of the "trapazoid" look of the image.
Jan 31, 2009 | Sony Office Equipment & Supplies
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Image Distorted
This is a classic convergence problem. Please confirm that your model is 51H84 and whether or not you intend to repair this yourself. You will need to know how to solder. If you wish to attempt the repair, confirm the model and update this and I'll provide you with details and instructions.
Dan
Oct 02, 2008 | Toshiba 51H84 51" Rear Projection...
Sony 52XBR Rear Projection
Sounds like some kinda convergence problem. Can you post an image please?
Jul 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Image is totally distorted
Did you also replace the bias resistors required when you converted from STK392-110 to the higher STK392-xxx modules? If I wer you I would go back to the orginal modules only new ones. Then I would also get a schematic to test the voltage levels on the chips to make sure they are the same as on the schematic.
Jul 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
663 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
