Question about Samsung Yepp YP-T9 Digital Media Player
Errors in Update File
I'm having a problem updating my Samsung Studio 5. Everytime I go to install the updates it get a Error msg, "Errors in Update Files, try again later." I keep trying but nothing changes. I've uninstalled the program twice. Any suggestions?
Thanks
  • 1 more comment
  • Anonymous Dec 10, 2008
    i have instalation problem
  • adayoldbagel Dec 25, 2008
    I have exactly the same problem. SMS gives a "errors in update files"
    Using Windows MCE :( and in USA.
  • eagle9924 Jan 01, 2009
    Same update problem with 'errors in update files' even though there are updates available. I have installed from a CD (with my YP-P2 player) and uninstalled and then installed from the Samsung website but still no joy.
    I have a problem importing video into the software as a lot of the codecs seem to be missing. There is other software that I am now using but it has taken be a lot of time and effort to get around the codec problem.
There is an error in up dating my samsungstudio 5. please help.
Posted on Jan 04, 2009
How do I fix windows error update 8 to 8.1 0x80070003?
copied from windows website.
Windows Update error 0x80070003 Applies to Windows 8.1, Windows RT 8.1 If you receive Windows Update error 0x80070003 or 80070003 when you use Windows Update, try running the Windows Update Troubleshooter.
May 15, 2014 | Microsoft Windows 8 For Tablets
Missing user32.dll
User32.dll errors come from issues inside Windows that involve the User32.dll file. This file contains important information regarding graphics details for objects such as dialog boxes. When there is an issue with the file, there will be problems when using other programs that use dialog boxes and other pop-up windows. Normally, a quick Windows update will solve all errors and problems.
Click the "Start" button and then "Run." This will open the "Run" window. Type in "wupdmgr". This will open Windows Update. It will now scan the computer to detect any necessary updates that are available from Microsoft. Turn on automatic updates by clicking "Start" again, followed by "All Programs," then "Windows Update." Select "Change Settings"; then select "Include recommended updates when downloading, installing, or notifying me about updates." Click "OK" and everything will be set. Windows will download the necessary update and install it to correct the User32.dll errors Hope this helps.
Jan 21, 2013 | Acer Aspire One Netbook
WHEN I TRY TO INSTALL " SAMSUNG USB DRIVE " I AM GETTING MSG " CAN NOT INSTALL BECAUSE NPS IS NOT AVAILABLE".WHEN I TRY TO INSTALL " SAMSUNG PC STUDIO " I AM GETTING MSG " INSTALATION FAILED"
The NPS Main error is quite common and well known problem by the Samsung. I suggest that when this happens you restart your computer, then your phone. After you have done this, try connecting again to your PC (it should not be necessary to click on "Search devices", if you need to there is still a problem).
If this doesn't solve your problem you can try to install an even newer version of New PC Studio (available under the GT-B2100). According to me, you need to go to the Samsung website and download the update software and the usb drivers for the phone , this should correct the crashing issue on the pc.
Uninstall and install again while the internet is connected. It would upgrade the PC studio after installation. The new firmware version IH8 is available through Samsung's New PC Studio which is currently only available for Windows users.
A new version of New PC Studio has recently been released, which has resolved this issue for many people. It can be found by visiting www.samsung.com and going to the download centre. The new software only appears under the Tocco Ultra (GT-S8300) for the moment.
A step-by-step version of my solution is here:
1. Make sure you have administrative rights to the computer;
2. Install the USB Drivers from the CD ROM (remembering that this doesn't actually install them at all on an XP machine! I have no Vista or W7 environment to test with so I can't comment if the behaviour is different);
3. Connect the phone using the supplied USB cable and select PC Studio mode on the handset;
4. Bring up the XP Device manager (right click on My Computer, select Manage and click on Device Manager)
5. Find the SAMSUNG Mobile Modem entry which should be identified as being in error state;
6. Right click on SAMSUNG Mobile Modem and select Properties;
7. Go to the Details tab and note the bit of the string between "&"s that contains PID_xxxx;
8. Use Windows Explorer search to find the PID string for your phone in the c:\Program Files\Samsung directory hierarchy (should search all subdirectories) and note which USB Drivers sub-directory contains the string. (Mine was '3', yours could be different;
9. Go back to the Samsung Mobile Modem Properties panel (from Device manager) and select General tab;
10. Using the Install driver button to start the Hardware Update Wizard make sure the "Install from a list or specific location (Advanced)" radio button is selected;
11. Make sure the "Include this location in the search" tick box only is checked;
12. Click "Browse" and navigate to the directory identified at 8. above;
13. Click "Next" and hopefully the driver will be installed;
14. If Device manager reports a different device in error state then repeat from 9. for that device.
Hope this helps anyone who is stuck with this.
Jun 20, 2010 | Computers & Internet
I have tried installing the pc studio software for my samsung phone (Jet Black) and get this error this program will exit due to the NPSMain error - every time please help
There is currently only one solution you can try to fix this problem and if the problem persists you will have to directly contact samsung support about this.
Open my computer>Open C drive>
browse to the install directory of PC studio that is:
C:\Program Files\Samsung\Samsung New PC Studio on my PC) and double click on the NPSMainChecker.exe
then click the update boxes and NPS will slowly download and update itself, removing previous NPS installation issues and errors.
Samsung phone support:
1-888-987-HELP(4357)
Mon - Fri : 7am - 9pm (CST)
Sat : 9am - 6pm (CST)
Good luck and thank you for using fixya.
Apr 25, 2010 | Cell Phones
Ps3 error 80710723
could be corrupted file, try to download again..copy to a pendrive correctly formated..put the update file and try to update again..good luck..try with another pendrive...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Computer Crashes -- error msg is that GEForce 4 (4000) is causing my crash
It may not be video card it could be system files at fault I had similar and some files were not indexed
go to C:\ right click Properties / Tools error check check errors new box opens tick the small square to fix errors and reboot while rebooting windows will scan disk and fix errors and if you are quick enough will see what it fixed then it will restart
I scan disk to fix errors every 3/ 4 weeks and do not have may problems
Aug 13, 2008 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
Samsung yp-s5 wont show up in computer
try un installing it and install it again
Dec 19, 2007 | Samsung YP-K5 MP3 Player
Samsung Yepp YP-T9 Digital Media Player Logo
169 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
