Question about Maytag MER6755A Electric Kitchen Range
H3 133 diplayed on screen. Range inop.Maytag MER6755A rage.
I have a Maytag MER6755A range.
A few days ago I opened the oven lid and the display on top started flashing H3 133. I restet the clock and continued cooking on the stove top. Now the top will not work at all and if I try to turn it on the H3 133 will start flashing again.
Thanks for your help!
  • ernesto_rosa Dec 09, 2008
    I STILL NEED HELP !!!!!
Noggin
  • 944 Answers
SOURCE: Oven not working properly
Do you mean 200 degrees Celcius or Farenheit? If Farenheit then the most likely culprit would be the thermocouple in the oven which can usually be replaced relatively easily by someone mechanically minded, if Celsius then you should suspect the elements although a working broiler would suggest that there is at least one element that works fine. Maytag says; "Why won't the oven heat up? First, make sure you've properly set all the oven controls. Check your user's guide for more information on your model's controls.(see below for the link to the manual if you need it) If your range offers the option of a delayed oven start, check to see if it's been selected. If so, the oven won't begin to heat until the selected time. If your oven has a lockout feature, check to see if it's been selected. If so, it will prevent you from using the oven. If your oven still won't operate, please contact an authorized Maytag service provider for more assistance." Here is the link to the manual; http://www.maytag.com/assets/product/8113P564-60.PDF and here is the link to Maytag Service if you need it - hopefully not; http://www.maytag.com/support/service_parts.jsp The other possible culprit would be the electrical supply to the oven - it may be adequate for the stovetop or grill but the oven may draw more power than the circuit can handle - even if it was fine before, this can change and may be caused by corrosion, rodents, overloading etc. and may not necessarily trip the breaker switch - if you suspect this at all then get a qualified electrician to check - it shouldn't take long to check so should be cheap, although repairs if necessary may cost more Hope this helps :)
Posted on Jun 22, 2007
aborcass
  • 2651 Answers
SOURCE: Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Posted on Mar 23, 2008
  • 116 Answers
SOURCE: I have a Maytag Performa
I am assuming that element does not come on at all...
A good place to start is the temperature probe . If it is Reading too high, its signal the control board that it does not need to heat.
Alternately the control board may not be acting properly.
Posted on Jul 28, 2008
appldoctom
  • 311 Answers
SOURCE: Broken glass top range
im sorry about that.i have replace many of those running around 400$,that a lot of money.i have see glass top stoves on sale 4 that much.and i think they all are about the same as quilty goes.God bless,tom
Posted on Jan 02, 2009
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Posted on Mar 05, 2009
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
Display codes
what kind of oven and model, run this on a computer, just put it in the browser, i can run it for you but need the type, maytag or other ect. Matt
Oct 29, 2017 | Maytag MER6772BAS Gemini Electric Kitchen...
Lower oven door locked and unable to open the door.
I have the same problem. Happened a few days ago. Have you found a solution?
Oct 30, 2010 | Maytag Gemini 30" Self-Cleaning...
I have a maytag MER6772 Gemini Electric Rage it gave the F1-2 code. What must I do to Fix This Problem?
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Jan 16, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gas oven after self-clean cycle door locked "dr" on displa
unplug it and let it stand for a few minutes
let the e- prom clear
plug it back in, should unlock
if it does not you need a new sensor
Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
Range
un plug the stove and plug it back in.
Dec 08, 2008 | Maytag Kitchen Ranges
Maytag clock
my screen shows locked on my oven and the oven door won't open
Nov 03, 2008 | Maytag MGR5751AD Gas Kitchen Range
My maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
Hello roborrob,
Welcome to fixya,
You said, Your Maytag oven's clock won't turn on. It just says "OFF", but there is a lack of a visible on button. The range works fine but I cant bake because I cant set the time let alone a temperature.
What is the model and year of your range?
Try to turn off the rage and then throw the breaker of for 5 minutes and then see if this sresets the system.
How long has this been going on?
Or did it just start ?
And how log have you had this range working fine!
Huuum
Oct 06, 2008 | Maytag Kitchen Ranges
WHIRLPOOL ELECTRIC RAGE
Replace the sensor. Pretty easy. It's in the upper left or right corner of the oven close to the broiler.
Oct 10, 2007 | Whirlpool SF367 Gas Kitchen Range
No display - oven/timer/clock inop.
Most likely control / clock has gone bad and needs replacing
Nov 11, 2017 | Frigidaire GLEF396 Electric Kitchen Range
Maytag MER6755A Electric Kitchen Range Logo
205 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
