Question about Janome Memory Craft 4000 Sewing Machine
Change width selection
I need to change the width selection from 10 to 12 stitches per iinch. How is this done? It does not explain very well in the book. It is very confusing. Any suggestions??
Patti
Do I really have to pay for assistance? If so problem solved as I will go to the dealer and ask assistance.
Posted on Dec 06, 2008
What setting do I use for blind hems on Viking 183
Select the blind hem stitch. Be sure to have the correct presser foot. Then set the stitch width so the "zag" will catch the fabric fold and set the stitch length so there are probably about 10-12 stitches per inch.
Aug 11, 2017 | Sewing Machines
How can I change width of stitch
width has no way to be widened only length can be changed. try setting on zigzag and then to the max length on stitch.
Aug 02, 2017 | Sewing Machines
Normal sewing setting
Stitch width set to zero, stitch length set to 10 or 12 stitches per inch. (No decorative designs should be selected.)
Apr 28, 2017 | Sewing Machines
How can i change the stitch type
On a sewing machine, it would be the stitch design selector in conjunction with the stitch length and stitch width selections. For a zig-zag stitch, a stitch width selection higher than zero will give a wide stitch.
Apr 17, 2017 | Sewing Machines
What is the setting for regular straight stitching?
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
Sep 22, 2015 | Bernina 1008
Mode selection button won't change stitches
1. The mode selection button tells the style of stitch you want.
2. Move the width adjustment above zero.
3. If this doesn't solve the problem then it is likely to need cleaned and lubricated.
Mar 21, 2015 | Singer Sewing Machines
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
Please explain to me how to adjust the numerical, digital buttons on my 7430 Singer sewing machine?
I just took a look at your user's manual, and boy--you're right, and I've been a computer systems engineer for about 30 years!
Actually, it's easier to figure out by DOING rather than looking at the description on page 35. Basically, selection is divided into two categories--utility, that is, stitches you would use for ordinary sewing, like stretch stitches, zigzag stitches, straight stitch, buttonholes, etc. That is located on the left column, with the arrow keys used for navigation in the middle. The display only shows 5 patterns at a time, so to see all of them, you have to keep pressing the down arrow. Once you have selected the stitch itself, you can then select the stitches width and length, and if it's available for that particular stitch, you can mirror (flip) the stitch, and use a twin needle (if it's available for that design)
The decorative and letter stitches are selected on the right column, and work he same way--they are displayed 5 at a time, etc, and selecting stitch width and length, mirror, and twin needle. However, additionally, you can choose to have the pattern sewn once (the default) or continuously.
I hope that helps!
Sep 21, 2014 | Singer 7430 Sewing Machine
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Sewing Machines Logo
59 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
