Question about Car Audio & Video
Buying and Installing a CD Player for my vehicle
I want to a) remove the factory installed radio(which does not work) and install a CD Player for my vehicle listed below. I am looking for a low cost solution even if I decide not to install it myself.
I need some adice on how to go about this.
Thank you!!
    Problem Solver:
  • 41 Answers
Most factory stereos are larger than after-market stereos, and after you install an after-market stereo there will be a large gap where the factory stereo used to be. You can go to most stereo retailers to find an install kit specific to your model of vehicle. It is possible to install the stereo yourself, but from experience it has been easier for me to just take it to a retailer and let them do the dirty work for you. Some retailers even offer free installation with/without a minimum purchase.
Posted on Dec 05, 2008
I have a 2004 freestar s with a factory am/fm radio. i installed an am/fm/cd radio. it will not recognize cd's in the player. tho original radio has only 1 plug port, the new radio has 2 ports. is the...
is it a new cd/radio ? the wiring is the same for a radio with or with out a cd player , the cd should work once the radio is connected , the other port you mention may be relevent as the original radio was a factory installed , these are usually designed to be useless to be used in other vehicles as a theft deterrent , i would remove the new radio and have a good search in the radio space as there may well be the second connector you require , be very carefull as there are many sharp edges and the apeture is not very large , the second connector , if there, will most likely be taped to another loom so as to keep it away from touching other parts so a good torch and have a search , keep me posted if you wish
Mar 11, 2015 | 2004 Ford Freestar
Factory radio wont work
Make sure the wires for the new radio are color to color when installing it in your vehicle aka the wires behind the CD player. Make sure all of them have connectors not the black tape cause it will melt and could cause a fire.
Sep 01, 2013 | Toyota Corolla Cars & Trucks
Cds trap in 2002 Trailblazer factory installed am-fm mp3 player
you should be able to pull it out and take the top off
Dec 13, 2009 | 2002 Chevrolet TrailBlazer
Here ya go!
Exploded view of the radio, tape player or CD player removal, 1990-94 vehicles
  1. Disconnect the negative battery cable. Wait at least 60 seconds before beginning the remainder of the procedure, in order to disarm the Supplemental Restraint System (SRS).
  2. Using a plastic trim tool, remove the radio panel. Pry the lower part of the radio panel away first, then separate and remove the panel.
Using a plastic trim tool, carefully pry the radio trim panel away
Remove the center trim panel for access to the radio retainers
WARNING When removing and installing the floor console, do NOT allow it to bump against the SRS-ECU!
  1. For 1995-98 vehicles, remove the floor console assembly, as outlined in Section 10 of this manual.
  1. Remove the mounting bolts and pull the radio receiver, tape player or CD player out slightly. Detach all harness connectors and remove the unit from the vehicle.
After removing the console, unfasten the radio mounting screws
Pull the radio out enough to access the connectors
Unplug the electrical connector from the rear of the radio ...
... then disconnect the antenna lead and remove the radio from the vehicle
Installation is the reverse of the removal procedure.
Oct 29, 2009 | 1992 Eagle Talon
Wiring difference
If your installing a stock radio/cd player from another Dodge the wiring plug is the same and will fit.If your installing a aftermarket radio/cd player(JVC,Pioneer,etc)you will need to buy a adapter plug that wires up to the radio and is a direct fit to your factory wire harness,so your not cutting your wires.When you buy the adapter plug it comes with a wire diagram of which wire is what.Your aftermarket radio should have a diagram also,either on it or in the manual.Hope this helps you.
Mar 04, 2009 | 2002 Dodge Caravan
New cd player installed but no sound!!!!!
First be sure thet all wires are properly connected and that the units output sound controls are adjusted (balance & fade etc.) has many valueable resources that may assist you.
Good luck
Feb 22, 2009 | JVC KD-G110 CD Player
No sound from speakers
did you check to make sure your vehicle didnt come with a factory amp, if it has one is it turning on? or did you remember to disconnect the negative battery cable while installing your radio, i know thats a dumb question, once i was installing a pioneer a barely crossed a couple wires and fried the radio, the radio itself worked fine and all the features etc, but it never did play sound again. i always disconnect the power now!!
Dec 26, 2008 | Pioneer DEH-P4000UB CD Player
Installing cd player in my caravan
Just get an adapter harness. they are only about $10.00, and will plug into your factory wiring, just like the stock radio did, and then the other end plugs into your new radio. Skoche (sp!) is the major manufactuer fof these (WalMArt caries the in car audio), also ebay.
Jun 25, 2008 | Car Audio & Video
Installing Alpine CDE-9852 CD Reciever In A Ford Mercury Sable LS
well most commen tool is a phillips head screw driver (+) to remove components to get the old deck out you'll need a dash kit to mount the new radio in 15 buck from canadian tire or audio shop...
the easyest way to wire this up would be getting a harness to plug into the factory harness too get the color code and then u just make the connections red to red yellow to yellow makes it real simple that way... the other way is to get the hanes manual for your vehicle then find out what color each wire is then yu have to cut the factory harness wire up from the book takes alot longer but can be done its worth the 12-20 dollars to get the job done if you need more help ask
Apr 21, 2008 | Alpine CDE-9852 CD Player
No power
My guess is that when you pushed the player into the dash, you pinched a power wire, resulting in a blown fuse. Check the vehicle's fuse box. Most vehicles have at least two fuses that provide power to the radio, though they may not all be labeled as radio fuses. You may need to check all the fuses in the vehicle, including any fuse box under the hood.
Aug 06, 2007 | Xtreme Sound WMS303 CD Player
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
