Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER6772 Hello. I've owned my Gemini for 3 years and have loved it...but in the past since months...the 2 right eyes have stopped working...and of the remaining 2..only the back left one is consistent. The front right one goes on and off. HELP. ps...the ovens seem to work fine...only problems with the cooktop. Thanks, Tina
WhIzAtIt
  • 136 Answers
SOURCE: Maytag MER6772 Gemini ELectric Stove
F9-3 code means the latch on the oven is faulty. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=MER6772BAQ&PartCategoryName=&Keywords=latch
Posted on Sep 17, 2007
SOURCE: Maytag Gemini MER6772 keypad/ovens not working
I had same problem, error code F 1-8, shorted keypad. I was so frustrated I went ahead and tore it apart. There was a surprising amount of gunk and moisture between the plastic face and the actual contacts. I cleaned it up and let it dry out. It worked OK for a while, but the seal is not good, and moisture from baking is still getting into it. When it goes bad again, I'm going to take off the plastic face and just press the sensors with a pencil eraser. I'll probably replace the range within the year. No way I'm paying $385 for new pad + installation on 10 year old stove.
Posted on Jan 03, 2008
milten1
  • 1304 Answers
SOURCE: I want to remove the cook top off my Maytag Gemini
there are two very small screws on the corners above the door, some times more along the whole front
once removed your top will flip right up
Posted on Oct 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a maytag MER6772 Gemini Electric Rage it
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
Display Condition Remedy
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 16, 2010
jsrock516
  • 5911 Answers
SOURCE: replace top burner outer coil not heating
If you need to replace one of your surface burner assemblies, the following link explains how:
http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
The screws the hold the cooktop in place are usually located uder the the bottom front edge. You will need to open the oven door to see them. Use care not to lean on the oven door or you can cause damage to the door springs. If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Mar 18, 2010
Maytag Gemeni double oven stovetop stopped working
Thats the controller, you'd need to call a professional no quick fix for that one sorry. besides attempting to fix it your self will cause more damage than good
Jan 02, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Zigzag light in eyes but no hedache
NOT a doctor, just going to share a personal experience: I had an injury near my eye, and after a couple of months I started getting these 'flares'. They look like somebody shot off a flare in the distance and at the upper and outer edge of my vision of the injured eye. After numerous tests, nothing was found. A Neurologist opined that the optic nerve might have been injured. His advice, was to just give it some time and it may or may not clear up. It took well over a year for it to stop, but has never stopped completely. About once a month, "flares". As to your situation, maybe there's a co-relation, maybe not.
Nov 02, 2017 | Televison & Video
I've had my compaq presario cq61 for about 2-3 years. A while back it would occasionally have a kind of shaky/blinky screen but just in the past week it's like the screen has stopped working.
The problem may be due the graphics card or data cable or backlighting.
The data cable can be severed over time though opening and closing the display. This can be replaced.
The backlighting/inverter dies, some-times the windows desktop screen can be seen if one looks carefully. This can also be replaced.
Try connect your notebook to another computer's monitor via VGA or HDMI out.
If this works then the problem lies with your LCD screen.
Take care!
damnor01
Sep 11, 2012 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
Hello - I've had my SKYFi2 receiver for about 4 1/2 years. For the past 6 months it cuts in and out, as in, plays the station that I'm on, then it stops and just says "antenna". ...
Hi Kathy,
It sounds like its the antenna, although it could be the docking station itself, or even the receiver. The best way to narrow it down is by testing against other equipment (if you happen to have other docking stations and or antennas) If it produces the same result you know its the radio. If you swap antennas and it works, obviously the antenna; and the same goes for the docking station. You can find replacements at tss-radio.com.
Jun 15, 2011 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Why don't costco stock the magalite wireless motion detection lites anymore, model MB-DLM-82. I've bought 9 so far and would buy more but can't find them in Phoenix, AZ.
I'm guess they don't stock for they stop working in a few months.
I have three and after three months, they go on and off when they want to.
If it detects movement, they may or may not work.
Loved them until they went crazy.
There are many posts on the net about the problems with these. I'm probably going to ask
COSTCO for a refund. I suspect they've given plenty already.
See my post from today, Bob Bergg Michigan
May 17, 2011 | Costco Megabrite Wireless Motion Sensor...
How long before rimmel mousse makeup should be replaced?
General makeup shelve life - Concealer - up to 12 months Powder - 2 years Cream & Gel Cleaners - 1 year Pencil Eye Liner - Sharpened Regularly - Up to 3 years Eye Shadow - Up to 3 years Brushes - Wash every 2-3 months Sponges - Wash weekly and discard monthly Foundation - Water Based up to 12 months - Oil Based up to 18 months Lip Liner - Up to 3 years Lipstick - Up to 3 years Mascara - Up to 4 months Nail Polish - Up to 12 months
Dec 30, 2010 | Health & Beauty
Wireless desktop 6000 keyboard problem
Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Maytag MER6772 Gemini Electric Kitchen Range Logo
46 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
