Question about Sony VAIO VGN-FE770G Notebook
Vaio vgn-fe770g spill/no power
I spilled coffee on it a month or so ago and it shut down instantly. immediately disconnected battery and let dry out for several days. plugged power in and get nothing. no charge light, no power on.
so i'm assuming i fried the mobo. would this normally fry the cpu as well? just wondering if i can get a new mobo and use the current cpu or if i need to get both?
  • Anonymous Jan 07, 2009
    I spilled some coffee on my VAIO FZ21S. I left it to dry for abt 9 hrs as the spillage wasnt that bad. Now when i try to power it on it just lights up the power LED.
    President:
  • 2,110 Answers
It might be ur CPU or mobo or Both...So it is better to take it to nearest service center for check up...
Posted on Dec 05, 2008
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Vaio notebook cloudy/hazy/streaking display following spill
nothing we can do for this problem. throw it away and get a new one
Feb 27, 2017 | Sony VAIO VGN-FE670G Notebook
Hullo, I spilled wine on my sony vaio
spilling the wine could have caused a surge to your battery or charger either one could be damaged but if your battery is reading full and powers off at random then it is probably your battery and needs to be replaced
Apr 08, 2010 | Sony VAIO VGN-N250E/W Notebook
Spilled coffee on D600 notebook, power supply turns off when plugged in after had the notebook cleaned. is my notebook not fixable?
When the power supply turns off when plugged into the laptop it is indicating that there is a short. Remove your battery and try connecting the power adapter again. If the problem persists your motherboard will most likely need to be replaced.
There are companies out there that will repair motherboards however if the laptop was on when the spill occurred there is little to know chance that the motherboard is repairable.
Mar 16, 2010 | Dell Latitude D600 Notebook
Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Mar 14, 2010 | Sony VAIO VGN-FE770G Notebook
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
I spilled a small amount of coffee onto the keyboard while the computer was in use. I immediately turned it upside down and dried it off. I cannot get it to power " on"
Don't power it on. If that is doesn't seem kind of all water proof kind. Take out the battery and the AC power supply. Turn the laptop upside down without closing the screen monitor and let the coffee be out. Dry it/or take it on a reputable shop( I may suggest).
Have it clean. Hope it doesn't fry something inside.
Sep 21, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
I spilled a little white wine on my Gateway laptop keyboard. I immediately turned it upside down, then removed the battery and power cord. I let it dry overnight (upside down). The next day I replaced the...
Please remove the Battery from the Battery bay and disconnect the AC Adaptor from the Notebook. Then, clean the metal contact in the Battery Bay and leave the Battery removed for half an hour. Next, connect the AC Adaptor to the Notebook and the power cable to a functional wall outlet and try to turn ON the Notebook. If the power LED on the Notebook doesn't glow then again disconnect the AC Adaptor and try removing and reinserting the RAM module. If the issue persists even after performing all the above steps then service will be required.
However, if the Notebook turns on after performing the above mentioned steps but the Battery is not detected then perform C: Drive Restore using the VAIO Recovery Center.
As per the specification published online, the Computer model VGN-N250E is preinstalled with the VAIO Recovery Center in the hidden partition of the Computer. You may use it to perform C: Drive Restore to restore the Computer to the original factory settings. Please make sure that the new Battery is installed in the Computer while performing the Complete System Restore.
Performing a C: Drive Recovery will erase all the data present in the C: Drive only and will reinstall the pre-installed Operating System, Applications and the original Drivers supplied with the Computer.
Please restart the Computer and keep on tapping the F10 key to access the VAIO Recovery Center. Next press the Enter key then select the "VAIO Recovery Center" option then follow the steps given in the link mentioned below to proceed with the C: Drive Restore.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C473668
In the link given above, please click on the sublink "Restore C: Drive" to view further information on performing the C: Drive Restore.
Performing all the steps successfully should resolve the issue.
Jul 12, 2009 | Sony VAIO VGN-N250E/W Notebook
Spilled small amount of liquid on it now it does not work. Looking for possible solution, ie motherboard.
remove the battery open up the notebook then spray rubbing alcohol all over the computer keyboard and, especially where you spilled liquid; really soak it; wait 24 hours for it to dry; and, try to turn it on with the power supply connected
Jun 03, 2009 | Sony VAIO VGN-N250E/W Notebook
Sony VAIO VGN-FE770G Notebook Logo
206 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
