It has 4 captors but each time only the first one on left hand side gets burnt,i got same problem last year,i had changed the first and second captor
SOURCE: passenger side tail light keeps burning out
You can get a New Connector for it from Either your Auto Parts Store or the Dealership. This could be the Problem. Please Rate My Response! Thanks!
SOURCE: 2004 Volvo C70 console light
IT IS A LITTLE BULB IN THE GEAR SELECTOR SAME AS ASTRAY LIGHT IT COSTS 10.00 AT A VOLVO DEALER AND THE REASON IT KEEPS BURNING OUT IS THAT BUMPS IN THE ROAD CAN SHOCK IT AND YES IT WILL BURN OUT
SOURCE: 4 alternator replacements in 4 years 1996 maxima
Has anyone looked at the connectors to the alternator? I remember these types of stories from work, alternator after alternator, found 2 things to be the problem, one is the connector to the alternator was defective, makes a poor connection and destroys the new alternator, the other is very poor quality rebuilds from Kragen, Auto Zone and the like, use a factory rebuild, they cost more but they are just as good as a new one.
SOURCE: left hand park light not working
hi first of all check ur fuses with a good test light see if any are blown and if u had cut any wires when u took out the old stereo that would have caused the problem..
thank u
rate me!!
SOURCE: headlights (low beams) and brake lights keep burning out.
Hi, it sounds like their is a bad earth somewhere causing it to short out this can be difficult to find as it would involve removing the lights and checking all the earth wires.
But first make sure the correct fuse is fitted because if someone has changed the fuse and put one on with the wrong amp then this would keep blowing.
If you look in the fuse box it should give you a diagramme of fuse location and the correct type check this first as this is something that would cost next to nothing to repair.
If the fuse are good then get the garage to check all connectors and earth wires.
Hope this is some help to you let me know if you need further assistance
6 pin socket
6 pin plug
7 pin
socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug
& socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin
round plug & socket
1 left hand turn - yellow
2 reverse -
black
3 earth -
white
4 right hand turn - green
6 stop - red
7 tail, clearance, side
markers - brown
round socket
large 5 pin round plug & socket
3 earth -
white
5 right hand turn -
green
6 stop - red
markers - brown
large 7 pin
round plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
7 pin round
heavy duty plug & socket
1 earth -
white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
5 right hand turn -
green
6 right hand rear , clearance and marker - brown
7 reverse/auxilary -
blue
7
pin flat plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
flat socket
12 pin flat
plug & socket
2 reverse -
black
3 earth - white
6 stop - red
markers - brown
8 battery supply -
orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
