Question about Garmin nuvi 200W GPS Receiver
Garmin charger problems
Ok i have a garmin nuvi model number 19A259741 when i put the car charger on the back to charge it will not fit snug. i have to hold the charger in place for it to get connection. the charger works its just that it wont fit snug to get connection
  • sheltonplane Dec 05, 2008
    Ok now can you tell me where i could get it fixed and how much it would costs? I live near johnson city tennessee 37601 Thank you for your help
  • Garmin Master
  • 2,130 Answers
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Posted on Dec 05, 2008
  • SHARCNET-USA
    SHARCNET-USA Dec 05, 2008
    Do you know if your Nuvi is still under warranty? Have you owned it less than 1 year? If so, you can contact Garmin at www.garmin.com or at the number below. They will replace your Nuvi free of charge.
    US: (913) 397-8200 - Monday - Friday: 8 am - 5 pm
    US Toll Free: 1-800-800-1020 - Monday - Friday: 8 am - 7 pm
    - Jim
    SHARCNET-USA
My Nuvi Garmin 2595 lmt will only charge when attached to computer not car charger
Check the wattage output on the charger. It may not be the correct charger that you have for the device. If this problem persists, carry your device to a cell phone store preferably in a mall, then find the one that fits your device and purchase the correct charging cable.
Oct 09, 2014 | Garmin nuvi GPS
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Nuvi 760 will not accept charge from car charger. Does charge from USB. Car charger lights up indicating that 12V is OK. Fuse checks OK. When plugged into car Nuvi reports 'external source required for...
Your units powered cradle has probably died out, this is very common with the 7xx series, see if you have a friend or someone that has the 7xx cradle you could try. But it is a very common issue, if you do need a replacement one can be obtained from here http://www.gpscity.ca/garmin-nuvi-700-series-cradle-replacement.html
Hope this helps!
Mar 22, 2011 | Garmin Nuvi 770 Car GPS Receiver
Garmin Nuvi 750 car cradle/charger does not charge the unit. USB charger works, so not the battery. Replaced the cigarette lighter jack and still does not work. Problem must be in the dash mount cradle...
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
Nov 01, 2010 | Garmin nuvi 750 GPS Receiver
My Garmin Nuvi 270 has a charging problem. When I plug the car charger it automatically goes to computer charging mode and does not allow me to navigate and charge at the same time. I always charge the GPS...
This is because the socket in the back of the satnav is worn and prevents the mini USB plug being pushed in fully. Push it in further and it will be ok.
Oct 03, 2010 | Garmin NUVI 270 GPS Receiver
My garmin ran out of charge and when it was plugged in to the car charger it says loading maps then stays on the garmin page and goes no further...
Disconnect the nuvi from the car charger and connect it to your computer's USB port with the supplied cable (or any USB cable you have that fits it), and leave connected overnight (8 + hours).
You should be able to get the GPS to start up as expected after charging via USB port. if this happens again, simply repeat.
Jul 15, 2010 | Garmin nuvi 255W GPS Receiver
My Garmin nuvi 1260 T I can't use GPS with acharger
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 07, 2010 | Garmin nuvi 1260T Car GPS Receiver
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
The car charger that fits on the back of my garmin i have to hold it in with my fingers to get it to connect what can i do to fix this?
I need more info.... what is your Garmin model number? Nuvi 2xx? Nuvi 3xx, 6xx? Is this the GPS cradle or the plug that's giving you the trouble? let me know and I'll have a solution for you.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin GPS
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
717 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
