Question about Home Security
Inop 14" B&W CCTV monitor
Monitor made in China for ADT used by Lorex for 4-camera security system. Power supply inop. Has three outputs: one for TV chassis,one for the cameras and the third for another pcb I have not studied yet. Data on the plate is: Model HD14Q2144-A serial Q0305-0150B. 100-240 v, 50-60 Hz. Power supply pcb has: HGF-SF33.PCB.B, 2003-02-12, SF7.320.141B.
I am sure the problem is in the power supply since none of the outputs show any voltage at all no-load.
  • Karl Shumaker Dec 06, 2008
    The situation here is the company is so tight they will not approve a purchase replacement. So, if we want the system to work we gotta fix it! That means I am back to the schematic and reference voltages.
    Karl
    Problem Solver:
  • 8 Answers
You are correct. The power supply (trace) is a very high voltage device. If it goes out, you will receive no power anywhere in the unit. It will most likely be cheaper just to replace the monitor.
Posted on Dec 06, 2008
How do you monitor only 2 channels at a time on a lorex securtiy system ?
that can't be happen because all CCTV system dvr or nvr just split into 1/4/9/16 camera
Jun 13, 2014 | Lorex Home Security
Lorex WL2700 blue screen and shaking
plug the camera directly to monitor if no change check connectors and cable
Apr 14, 2014 | Lorex L23WD845 4-Camera Security System...
Cctv dvr beeping
Shut it down reboot it's saying that one of the cameras is not functioning correctly if this don't solve it then check all power supply's to each camera
Feb 06, 2014 | Swann Communications DVR4-Pro-Net...
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Dec 30, 2012 | GW Security Home Security
Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Sep 22, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Video
I HAVE A MICROMARK CCTV ITS A SCART TYPE IT TELLS ME IN THE INSTRUCTIONS TO PUT THE SCARTLEAD INTO THE SCART ON THE TV WHICH I HAVE DONE I AM GETTING THE PICTURE OK BUT THERE IS NO SOUND ALL I GET IS A HUMMING SOUND JUST LIKE YOU HAVE NOT TUNE IN THE TV PROPERLY I CANNOT TUNE IN THE TV AS ITS ON THE AV SO CAN ANYONE TELL ME WHY I AM NOT GETTING THE SOUND WHEN IT TELLS ME WHEN I PUT IN THE SCART THE SOUND WILL BE PICKED UP . OR COULD IT BE THAT ITS A TV COMBI VIDEO
Oct 19, 2008 | Lorex Weatherproof Color Day/Night Camera...
Home Security Logo
428 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
