Question about Ruud Central System Air Conditioner
Air conditioner/furnace squirrel cage fan remains running when th
When thermostat is shut off, squirrell cage fan keeps running. faulty thermostat or motor? thank you. RT
  • 85 Answers
Ensure you don't have a short in your therm wires. Disconnect them, if the furnace continues to run, you have a lockout problem at your furnace. When the motor on the fan fails, it wont run. Check for led codes on the control board. If you don't have led codes, turn off the power to the furnace at the breaker, and watch the unit. If nothing happens, connect the thermostat. If nothing happens still call for heat. Let the therm run through it's cycle, and if the bower runs continuous again, let me know we can walk through that situation.
Posted on Dec 05, 2008
    Problem Solver:
  • 14 Answers
Probably the fan switch stuck on the fan combination control or improperly adjusted. Turn power off, remove red wire on the relay from the fan motor. Isolate so no short will happen and turn power on.The motor should not run. The fan relay could stick also. You will have to use a volt meter and see if there is voltage on the coil terminals on the fan relay. Put 1 lead to ground and touch only the terminal for the coil on the relay with the other meter lead.It should not have 120volts. If it does it is not the fan relay but possibly a limit sending power to the relay. Try that first thank you J
Posted on Dec 19, 2008
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
Ac squirrel cage fan motor noise
Could be bearings going out, or a squirrel cage rubbing the blower housing, a squirrel cage blade that came loose, or a capacitor.
Jun 12, 2012 | Bryant Heating & Cooling
Mastercool plus 6500 thermostat problem
Posted also on the Cooler quick cycling problem:
My Master Stat Controller (CC2000A Rev 2003) was in 2 parts. The Thermostat unit in the house and the Power Control unit in the Cooler. The power Control unit was mounted on the squirrel cage fan housing so it vibrated some when running. That means the components vibrated slightly with respect to the PC board. Especially the larger components. My first symptom - Intermittent failure to turn the water pump on. I could see a faint crack in the solder around the pin of a relay on the PC board. Re soldering the PC pins solved that problem. Later, the second symptom was quicker than usual on-off cycling of the fan. I re-soldered all the pins on the PC board and all problems subsided. A better mounting place for the Power Control Unit would be good, but outside of the cooler might be a thermal problem here in the hot desert south west.
Apr 24, 2012 | Mastercool 67471 Evaporative Cooler Air...
Furnace is a Rudd UGEB model. Burners ignite and but the blower (squirrel cage) doesn't start. After a couple minutes they turn off and the blower starts and runs for less than a minute and shuts off....
Sounds like the fan limit was not replaced correctly. You can try switching the blower to the On position (instead of Auto), if the furnace runs properly with the blower on that would be the most likely culprit.
Sep 24, 2011 | Ruud UBHC Air Conditioner
Running not blowing air
sounds as if fan isnt attached to motor shaft. There is a set screw on the fan cage that if it loosens the shaft will turn inside of the fan not turning the fan( also known as a squirrel cage) You need to get access to the fan motor and see first if its shaft is rotating, if it is see if the squirrel cage is turning if not the set screw located on the inner collar of the squirrel cage needs to be tightened. Thie set screw is more than likly an allen set screw.
Jul 07, 2009 | Heating & Cooling
New furnace, goodman and reinstalling squirrel cage... unsure where to put red wire running from squirrel cage
Follow your schematic on the new unit. It will tell you where the wire goes. Some of the "extra" wires are connected to the main board close to where the "used" wires are and they are labled "spare". Find the blower motor on the schematic and trace out where this wire will go.
Mar 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman Air Handler motor will not turn off.
Look at your Thermostat wiring.
If there is a green wire going to the "G" terminal, disconnect it.
If it stops running, you have a bad T-stat.
If it keeps running, you either have a stuck fan relay or a low voltage control wiring malfunction.
Those are usually related to one of the safety switches having problems.
If green is not going to G, let me know, and we will determine which one is indeed the fan wire and go from there.
Remember, when you rate the solution, it closes further dialog, so only rate when you are satisfied with the discusion.
Thanks for visiting FIXYA!
Jan 03, 2009 | Goodman CLQ36AR49 Air Conditioner
Mod ASU24C1
If the blower is made of plastic it does not have a set screw. You most likely need a new squirrel cage. They are formed to the shaft and have a compression ring that holds them in place.
May 28, 2008 | Fujitsu 24C1 Air Conditioner
Ruud Central System Air Conditioner Logo
482 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
