Question about George Foreman GRV660 Toaster Oven with Convection Cooking
The lower heating elements do not heat up enough.
The top part of the food is cooked, but the bottom part is not.
Thank you so very much for any help. I really appreciate it.
  • Anonymous Dec 16, 2008
    I have the same heating problem but with the top heating elements. They do not heat up. Where can you buy the spare parts for this problem?
  • 368 Answers
Hi sibboah,
Go to
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Posted on Dec 30, 2008
Bravetti toaster oven
Not enough voltage getting to the heating elements. Look at the thermostat or the control board for the problem
Jul 28, 2017 | Toaster Ovens
The heating elements are inside on the top and bottom
Jun 08, 2013 | Bella Cucina 13049 1500 Watts Toaster Oven...
Elements not heating
Buy a new toaster. Very cheap appliance.
Feb 02, 2018 | Breville BOV650XL 1800 Watts Toaster Oven...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
    it is several prosibilites for your problem:
    1) the wire of the oven is damaged;
    2) the thermostat is decalibrated or damaged;
    3) one or more heating element is intrerupted or burned.
    1) check the wire an replace or repair where is posible whit similar heat resistant wire;
    2) replace the thermostat whit similar one;
    3) replace the heating element
    Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
    Burnt pie
    YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
    Apr 13, 2009 | Toaster Ovens
    Slow to heat Haier Convection Oven
    you are correct . it is the convection . the fan blows the air around and away from the elements ,when that is happening the elements can never get hot enough to glow , as the oven gets hotter and at some point the air is so hot even with it blowing the elements will start to get red ... this is good because todays elements are thin and cheep and melt easy so the fan keeps the heat away from them and the elements last longer ...... if this answer helped please rate it a 3 or 4 stars .this high rate will help keep me in the paid answer department ... thank you
    Apr 04, 2009 | Haier RTC1700 1700 Watts Toaster Oven with...
    Pizza is soggy
    Not working properly accordiing to the manufacturer.  Not fixable.
    Jan 27, 2009 | Toastmaster TOV200 Toaster Oven with...
    Lower heating eliments don't heat or glow. Only top ones work
    The elements are not orderable, but you can call Cuisinart with your serial number - the product has a 3-year warranty, and that is definitely a defect - will they glow if you put them on Toaster setting?
    -Tha Mp3 Doctor
    Aug 03, 2008 | Cuisinart TOB-175 1500 Watts Toaster Oven...
    Toaster does not work!!!
    I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
    Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
    George Foreman GRV660 Toaster Oven with Convection Cooking Logo
    203 people viewed this question
    Top George Foreman Toaster Ovens Experts
    Gerry Harvey
    Gerry Harvey
    Kevin Getz
    Kevin Getz
    Are you a George Foreman Toaster Oven Expert? Answer questions, earn points and help others
