Cant load the network could you please help me
Please check the network signal strength in your area or use your SIM with another phone. If this works then the SIM is in order and the phone has issues. Remove the battery and reset, then restart to see if there is network detection or there are issues in the hardware section and best be checked with a service center.
SOURCE: Nokia 6500 slide - RESTRICTION CODE
hi,
I have Nokia 6500 Slide locked to UK Orange Network.
IMEI Number is 352027027919833
Kindly help with a Unlock code.
Thanks.
CAISER NOMAAN
SOURCE: nokia 6500 slide orange restriction code
hiya. iv got a nokia 6500 slide on Orange in the uk, i need a restriction code, because i enter some codes in wrong, anyone know what i can do it get it fixed?
SOURCE: NOKIA 6500 SLIDE , NO NETWORK CONNECTION
plz backup ur data : contacts msg photos and try this code
*#7370#
then 12345 as the default security code
if that not working
the PIF is faulty its a amplificator circuit in the borad shud be replaced
SOURCE: my nokia 6500 slide keypads sometimes won't work
Mine does the same. A technician has advised me it's a flexi error.Yet if you want, you can do what I usually do lol...Slide your thumb progressively over button 3,then 2, then 1, then 4, then 7, down to *. Do this continuously and it should work after a few tries.
SOURCE: Nokia 6500 slide security code
NOKIA 6500 SLIDE ASKING FOR SECUIRTY CODE TRIED 12345 BUT DOES NOT WORK HELP
