Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Control panel flashing F05 ?
Washing machine has stopped mid way through cycle and control panel is flashing F 05 any idea what the problem is I have checked manual but it has no reference to this problem.
  • Hotpoint Master
  • 3,463 Answers
F05 denotes pressure switch jammed on full, check pump and draining out.
If still no go, then call an engineer.
Posted on Dec 07, 2008
My machine flashing up f-05 any ideas?
F05 indicates water level switch is sticking, possibly due to a blocked filter.
Remove lower rear panel of washer.
Remove large black hose connected to the bottom of the drum.
Remove and clean plastic filter inside hose.
Refit and test.
Mar 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Stopped mid cycle with the code F 05 flashing up, it has been tried since with the same thing happening. Not sure what the code means?
F05 means pressure switch jammed on full.
You need to locate and clean pump filter, if not at bottom front of washer, then remove lower rear panel, remove large black hose on bottom of drum, remove and clean filter inside hose.
Fit back and test.
Mar 02, 2010 | Hotpoint Aquarius WD640 Front Load...
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
My indesit 1300 stops mid cycle and flashes f-05 help
pump blocked take plastic trim off bottom and unsrew filter is main cause or poss pressure switch jammed on full
Jun 07, 2009 | Indesit W 123 Front Load Washer
Error code F05 after the start of wash cycle
F05 is a water temp sensor error ,could be a bad heating element, or the temp sensor may be faulty, try checking the connection's to the temp sensor and heating element, also check the element relay.
Apr 20, 2009 | Whirlpool GHW9100L Front Load Washer
F-05
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Apr 01, 2009 | Washing Machines
Machineflashinf f-05
If not :
Mar 09, 2009 | Hotpoint Ultima WD72 Front Load...
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
187 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
