Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP830 "Scanner not working properly", no light when I lift u the scanning bed
  • timandlori Dec 24, 2008
    My scanner appears ready to scan but you hit the buttons and nothing happens. I can print fine and Fax fine but scanner doesn't work..
  • Anonymous Jan 11, 2009
    I am having the same problem. No scanner but all else works fine.
3 Suggested Answers
SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Posted on Jun 09, 2008
SOURCE: Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
Posted on Aug 07, 2008
Scanner not working ... is there a way to fix ? is it cost effective to repair older machine?
scanners/ printers costs are as low as $35.00 for a new one and if it is a wifi unit may be $100.00 to replace new
with labor costs and parts ( if you can get them) I would consider junking it and get an updated new one
Oct 01, 2015 | Canon PIXMA MP830 All-In-One InkJet...
How to scan a slide on flatbed scanner
This model Canon MX700 cannot scan slides.
A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor.
I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
May 17, 2012 | Canon PIXMA MX700 All-In-One InkJet...
Release scanner lock switch
If you lift the lid of your scanner there will be a switch there, this will be set to lock, which locks the scanning lamp in place. If you flick the switch it should work as per normal
May 11, 2012 | Canon PIXMA MP830 All-In-One InkJet...
I am repeatedly getting error code 5010 once I scan any document.
Ok it can be either 2 things: The FIRST is if you have not UNLOCKED the scanner lock switch. The scanner lock switch is a switch that keeps the scanner assembly frozen in place so that when you move your scanner from room to room or apartment to house, the scanner wont freely move around the unit causing it to be dammaged.
To unlock the Scanner lock switch just lift your document cover and look for the swtch on the LEFT hand side of the scanner's glass bed.
SECOND: IF the scanner lock swtich is set at UNLOCK, then your scanner assembly is broken and needs to be replaced. You must then send it to Cannon or any Mulitfunction printer repair place.
I hope this helps you :)
Mar 15, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Scanner not working
You need to check the operator's manual. For the messages it gives, there is usually a solution for it.
Nov 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
"scanner not operationg properly" on my Canon MP830
Confirm the connection between the scanning unit and the
logic board.Replace theunit, orlogic board.
Sep 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
160 people viewed this question
old marine
old marine
