Question about Philips GoGear HDD6330 MP3 Player
FM radio not showing up
The fm radio no longer shows up on the main menu. It disappeared after doing a factory reset. How is this fixed? (If someone has the original files from a working player, maybe that might work if I could get those from someone)
    New Friend:
  • 161 Answers
Pico Wifi Internet Radio. Radio no longer connects to my WiFI...
First try making sure you are holding the reset button down long enough to reset the unit to factory settings. This can be up to 20 seconds. You will have to completely reconfigure the unit after that.
I hope this helps,
--Robert
Oct 28, 2014 | Revo Pico IR Portable Wi-Fi Internet Radio...
How do you access the fm radio on a Samsung GT-C3300K please. The user manual only mentions the mp3 player. Thank you.
To listen to the FM radio
1. In Menu mode, select FM radio.
2. Select to start the FM radio.
3. Select Yes to start automatic tuning.
The radio scans and saves available stations
automatically.
The first time you turn on the FM radio, you will be
prompted to start automatic tuning.
4. Control the FM radio using the following icons
and keys:
You can find the User Manual that show the FM Radio in this link. Look on Page 25 for the Radio Instructions
Apr 21, 2011 | Samsung Cell Phones
My Sangean ATS 808 AM/FM/SW Radio reciever shows a flashing E on startup and won't operate. Any answers on resetting or other solution?
Hello, I assume that this only happens when you are using it on batteries and the unit works when plugged into the mains. If this is the case it most likely is a faulty or dirty connection in the main battery chamber. Clean all contacts reload new batteries and try again.
Oct 17, 2010 | Sangean ATS 808A AM/FM/SW Radio
FM Radio was erased from the MP 3
OK this seems to easy a fix for you, but try it.
* In the main menu where it lists your options (and where FM Radio would be) press the 'Menu' button on your Microphoto (bottom right button) and there is an option to 'Configure Menu' and in there should be the option to show FM Radio again. Hope that helps you.
I have a similar, but different problem, so ill list below, maybe it will help someone out.
i also replaced the (broken) 8gb microdrive with 8gb compact flash in my Zen Microphoto, which worked flawlessly! BTW i bought the A-Data 'SPEEDY CF 8GB' from newegg.com.
My FM Radio still shows up, but only gets MONO sound on the Right channel, its very frustrating. i took it all apart again and made sure no connections were loose or broken, but everything seems perfect. i believe it to be a firmware issue, i think ill try to roll back the drivers. im using firmware 1.31.01.
its just annoying to have to roll back to Media Player 10 everytime just to install the firmware and have windows properly communicate with the zen... :[
Nov 20, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Nokia 5220 expressmusic FM radio always says off
I have the same problem and don't see a way to set the frequency of the stations if you can't set the radio to on...............
Nov 07, 2008 | Nokia 5220 XpressMusic Cellular Phone
Sportster 4 - FM Transmitter
It is supposed to be there. I have also never heard of this, but it sounds like some of the software is missing. Try a reset to factory default, and if it does not show up, accept the reconditioned unit. After all, if u send yours in to be fixed, it is now a reconditioned unit anyways. If it has been less than 30 days, you can return it for a full refund to wherever u purchased it from, and then start all over again buying a new unit. But the reconditioned units have the same warranty as a new one. So if it's past 30 days, might as well accept it.
May 09, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
No radio in menu. only music. voice .settings .
The service may not be available in your area. Make sure the headphones are connected to the player when searching for radio stations: Here's pg 15 of the user manual:
FM Radio (if applicable)
The Sansa
player includes an integrated FM radio for listening to live broadcast FM
stations. Please note that the FM Radio function may not be available in your region.
Listening to FM Radio
To listen to live broadcast FM station, follow these steps:
1. Select FM Radio from the Main Menu.
2. A radio frequency menu will appear.
3. Press |<< or >>| to adjust and search for the desired frequency, or select
preset by pressing Select.
4. For fast search, press and hold the |<< or >>| buttons.
Feb 20, 2008 | SanDisk Sansa Clip MP3 Player
FM Radio Feature Completely Disappeared!
Yes this is a common problem with no soultion. could try taking it apart and reseting all the connectors inside see if that works?
Jan 08, 2008 | Creative Labs ZEN Vision:M Digital Media...
No FM Frequency option
I had the same problem with all three of my Roady XTs. I posted a video with directions for solving the problem on YouTube:
http://www.youtube.com/watch?v=BGMWf0aUTjw
Basically, you just need to have the antenna unplugged when you power up, and push menu right away, then select. Not sure why, but it worked on all of my Roady XTs. On the oldest one I had to push menu more than once. Good luck!
Sep 24, 2007 | Delphi Roady XT XM Radio Receiver
AM/SW no longer functioning - FM still works fine
If it can fixed at a reasonable price, it might be better to try to have it repaired.
Hope it helps.
Sep 15, 2007 | Grundig G4000A FM/AM Radio
Philips GoGear HDD6330 MP3 Player Logo
361 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
