Question about ASUS K8V-MX Motherboard
Asus K8V SE Deluxe - will not turn on
Just installed Asus K8V SE Deluxe with AMD 3000+ 64 and 3 GB RAM. Getting power to the MB but ATX Power switch seems useless - system will not start. ATX Power and ATX 12V 4Pin connected. When Power Supply is switched on system fans spin up and the SB_PWR LED lights. Pressing the Power Switch has no effect. Cleared RTC RAM, rechecked panel connections. Power supply is new Antec 850 Quattro but old Power Supply had the same result. Wiring for panel switches ok - worked fine with the ASUS A7V just pulled out.
  • 1 more comment
  • mebedug Dec 11, 2008
    good suggestions but neither one worked, replaced bios chip with new and problem continues......
  • mebedug Dec 12, 2008
    Tried to boot from cdrom but no devices other than fans will spin up. thinking i may have a fried power switch circuit - ohmed out and got nothing where other motherboards give a reading on the power switch circuit
  • Anonymous Mar 23, 2014
    Asus x58l wont start-up, when I switch on my laptop, all the normal lights blinks up, fan and dvd-rom starts normally, but there is no display. there is a continuous sleep (Z) light which blinks and stays on.
    I have change battery/AC, Ram/hard disk, but it doesn't help.
    thank you.
    Sergeant:
    Champion:
  • 362 Answers
It should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
Posted on Dec 05, 2008
  • james kilgore
    james kilgore Dec 05, 2008
    it should have pins to reset it touch the two reset pins with screwe driver to activate it if still gont work you have a bios problem
    Sergeant:
    Champion:
  • 362 Answers
If that isnt it you have program trouble try a repair on your harddrive windows set up to boot from cd rom and if it dont getect hard drive thats problem
Posted on Dec 11, 2008
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
Jan 27, 2011 | ASUS K8V-MX Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Can windows 7 be installed on asus k8v-mx mb with amd sempron 2.4 1gb ddr1ram
this is the minimum spec for Windows 7:
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
  • Internet connection (to download the Beta and get updates)
Its not the motherboard, its the processor speed, RAM size, and hard drive space, and video card capability that counts.Your processor speed well meets this criteria and also your RAM size is within spec for Windows 7, and im sure you will have in excess of 16GiG hard drive space. So its all down to your video card. You may need to install DirectX 9.Hope this helps :)
Feb 14, 2010 | ASUS K8V-MX Motherboard
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
Asus k8v se deluxe motherboard
You talking overclocking? That is only with amd cpu's and if you have a amd you need a overclocking tool www.overclockers.com should help you in this regard.. Please leave me good feedback as we do not get compensated for free questions so we look at your vote for out gratitude thanks..
May 15, 2009 | Computers & Internet
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Backup server won't boot up
Is it USB or SATA drive? In the BIOS there is an option to allow USB boot device.
Jan 15, 2009 | ASUS K8V SE Deluxe Barebone Kit / ATX...
K8v se deluxe system failure
Sounds like your board may have fried. Try to hook it up to just the power supply and see if you get anything from that.
May 28, 2008 | ASUS K8V-SE Deluxe Motherboard
ASUS K8V-MX Motherboard Logo
350 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
