Question about GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 adora Microwaves shuts down
My microwave shuts down after a few minutes of use. It is as if the circuit breaker tripped. After a few minutes I have to reset the clock and it operates. I notice there is more steam than I remember in the oven. Maybe the interval vent is not working?
  • nemo45 Feb 03, 2009
    I ad the same model. Ge came out and told us it was a leaky magnetron interfering with the control panel. Althought the part is covered on warranty the labor is not. Eventullay the problem got so bad ours jsut died. We jsut bought a new one. Its very frustrating to see the number of posts for this problem.
    I know there was another thread that pointed to some home made solutions. Also if you can find someone to replace the magnitron, the part is free.
  • GE Master
  • 9,086 Answers
It sounds like the magnetron is overheating and opening the thermostat.
This can be caused when the internal cooling fan is not running or by a magnetron that is failing.
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the magnetron will be destroyed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Dec 07, 2008
Is there a thermastat in ge adora microwaves that could overheat
there are couple protection thermostats on all microwaves. one is cavity t-stat, one is magnetron tstat. if it gets too hot inside the microwave usually cavity thermostat is wired the way that all power will go off to microwave, it will open circuit(usually they not resettable). If magnetron tstat opens up, usually will open circuit to magnetron only (so light is on, seems to run, but no heat). I Hope that helps.
Mar 01, 2015 | GE Microwave Ovens
Started tripping circuit breaker. It's on a 15 amp circuit, we bought it two years ago and it only started doing this last week. It first did this 7 minutes into cooking a frozen meal. Then four minutes, 3...
The problem could be a failing magnetron or control board. The tingle may be traceable to a faulty receptacle installation - one with a floating ground or incorrect wiring such as reversal of the hot and neutral lines. The vibrating sound seems to be one of the quirks of GE microwaves.
Apr 28, 2017 | GE JES1358 Microwave Oven
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Adora Spacemaker XL 1800 is no longer heating the food. What do I need to do to replace the microwave emitting bulb?
may be , the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. it need to be replaced .
Jan 11, 2010 | GE Microwave Ovens
My GE Spacemaker XL 1800 was working fine and
check fuse inside unit microwave has a fuse around 15 to 25 amps get at local hard ware store u should discharge capacitor before installing fuse not nessary in microwave
Jul 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
GE Spacemaker XL 1800 Micro - " Turns itself off after 2 sec. "
It looks like a component is short-circuited and then it acts to protect. Call a service.
Sep 21, 2017 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
160 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
