Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
CD/DVD ROM not working properly
I've had this laptop since 2003. Recently, the CD-ROM drive will occasionally flicker out of service in the middle of an active Windows session. The only way to remedy this is to power down the system, wait, then reboot. Even then, that doesn't always work. I've removed the device from the device manager in Windows, and a reboot shows it coming up again. Unfortunately, the issue remains. I originally thought that this might be a Windows issue, and, since my system is long overdue for an overhaul and I'd like to switch to Linux, I tried to boot into either a Live CD distro or a boot CD. Even though the BIOS is set to boot from CD first, it skips right past and goes directly to the hard drive. I am completely unable to even reinstall an OS on this system. I figure that this is now a hardware issue, but if anyone has ideas on what I can do to further troubleshoot, that would be greatly appreciated. Also, if anyone has any spare drives lying around cheap, or can recommend an inexpensive replacement, that would be great. Thanks, Larry
  • Anonymous May 17, 2009
    can not boot from cd/dvd rom
    Sergeant:
  • 310 Answers
Hey as long as it was an original Windows disc you tried booting off of, as copys will not boot off the cd alot of the time, it sounds like the cdrom drive is at fault, a new one will set you back about 40pounds maybe 60 dollars i use www.ebuyer.co.uk but thats a uk site, you should try www.ebay.com or amazon. to maybe get a good deal... All the best John
Posted on Mar 03, 2007
My dvd drive is not working it is not showing its on my computer folder.I am using windows 7 recently i had this problem so can u help me ..
make sure both the power pin and sata pin are connected properly ,if both the wires are connected properly and still having the problem goto run and type "compmgmt.msc"(without quotes) and select disc management if the dvd drive is showing below the hard disks means your dvd drive is working fine only thing you have to do is to right click on the CD-Rom 0 and change drive letter and paths to it
.if the CD ROM option is not seen in disk management then you have to go to the device manager option under computer management and expand cd/dvd -rom drives and you will find your dvd drive model if not that means that your dvd drive has got hardware problem
Aug 05, 2011 | Computers & Internet
Recently formated my laptop via a usb flash drive since my cd/dvd rom doesnt seem to work,and unfortunately the cd/dvd rom still doesnt work,doesnt appear under my computer,i ve no way of accessing data on...
Hello
Head of to the Acer website.Put in your model and serial # of your laptop. Find and download the cd or dvd drivers and install them on your laptop.
Also have you done the windows updates? Usually this will solve the problem.
Mar 25, 2011 | Acer Computers & Internet
How i install window in MM10-PC sharp laptop
Installing windows in Personal Computer are needed Bootable at CD/DVD Drive. Your problem is you don't have any CD/DVD Drive.
Use a Portable External CD/DVD Drive.
It's available in the market.
Aug 23, 2009 | Sharp Actius MM10 Notebook
I cannot get a dvd to play, nor can eject it
I think you have CD RAM and DVD ROM i had also the problem of read dvd but i buy CD/DVD RAM Now my drive is working properly and successfully
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and
DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data
to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Apr 17, 2009 | Dell Inspiron 1200 14.1 XGA LCD...
Cd drive application not found
first u have to purchase the lance cleaner and clean your cd rom or dvd drive after that your cd rom run properly working...
Apr 06, 2009 | Computers & Internet
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I"ve lost my (E:Drive)
Welcome to Fixya
This can happen due to Three problems.
1) Might have disabled the DVD rom. To check this, Goto control panel->DeviceManager->CD/DVD Rom. Where you can enable/disable the device.
2) The Drivers for the DVD rom may not be installed or may be corrupted. Please use the drivers cd or visit the dell site to update the drivers.
3) The CD DVD Drive may be loosely connected. If can risk at opening the chasi and try connecting it properly
The system may need to be restarted if you perform any of the above activities.
Rate the solution appropriately.
Feb 07, 2009 | IBM ThinkPad T23 Notebook
DVd-rom replaced but not working properly
check the copyright settings on it, most dvd's have that so people don't bootleg it and re-sell it, check to see if there is any scratches on it, check for dirt, or take it to customer support and get a new one
Jan 28, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
Old DV-rom replaced and not working properly
do you have the software installed to watch movies ? and check dvd for scratches , and check lenses and everything on DVD-Rom
Computers & Internet Logo
513 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
