Question about Brother P-Touch 1180 Label Printer
Hi I have the p touch home and hobby label printer and do not know how to load the tape can you please advise?
  • 120 Answers
Http://www.brother-usa.com/Manuals/default.aspx?ProductID=PT1830&ProductGroupID=8
Click the link above, select the model you have and download the manual.
Hope this helps.
Posted on Dec 05, 2008
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
I have an "old" p
When labels print i get back ground i do not want
Mar 04, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
Cant find label refills
Hi there, Go to Find.com and key in Brother BRTPT65 P-touch Model PT-65 home and hobby label refills. It will take you to a varitey of different labels showing the prices. Make sure you click on the labels and make sure they are the ones compatable with your machine. Hope this helps!
Jan 15, 2011 | Brother BRTPT65 PT-65 Label Maker Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
P-touch Model PT-100 not working
You could send it back to the Manufacturer but you will find that the cost of doing so would be not far less than buying a new one
Dec 03, 2009 | Brother P-Touch 1180 Label Printer
How and where do I feed new labels
press and hold the code button and press the "space button" this will feed the tape
Feb 18, 2009 | Brother BRTPT65 PT-65 Label Maker Printer
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Dec 28, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Ink will not print
www.ptouchdirect.com/ptouch/umpt65.html
this is a web page with the manual should help
Dec 09, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-Touch 1180 Label Printer Logo
91 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
