Question about True GDM-12 Refrigerator Commercial
Commercial TRUE GDM soda machine
Our TRUE GDM soda machine (glass doors) for commercial use.. is not making the soda's cold... I called someone in and hes charging $95 just to come out and look at it tom.. meanwhile i put the sodas in the back cooler for customers.. Any suggestions as what could be the problem... yesterday my brother was restocking all the sodas and had the glass doors opened for 2 hours.. and later at night we noticed that it wasnt cooling the sodas.. I changed the temp about 3-4 times but its not making any difference and only warm air is being blown out of the fans.. not cold air... and when u slide the doors open it stink..PLEASE HELPPP!!!... I dont have much money to pay someone to fix it.... ANY SUGGESTIONS???
    Problem Solver:
  • 7 Answers
If the cooler has power, the condesor fan (bottom) and evaporator fan (top) are spinning put your hand on the compressor. Do you feel a vibration? if so, you probably have a refrigerant leak. If not (if its clicking or nothing at all) its a compressor issue.
Posted on Aug 13, 2009
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Cooler just stopped getting cold
Can you hear compressor running? Any airflow at the compressor? Might need a start kit. Call someone if your not handy at electrical.
Aug 13, 2013 | True GDM-12 Refrigerator Commercial
I have TRUE freezer model number GDM-49F. the compressor start but the evaporator fan wont start what culd be the problem
Could be a number of things. It has a thermistor that sits on the evaporator to keep the fan off until it gets cold. It also has a switch above the door that switches the fan on when the door's closed. It could be a loose connection in the wiring, or, lastly, it could be a seized fan
May 04, 2012 | True 49 cu. ft. / 1388 liter Commercial...
True GDM-72f freezer Fans don't start
Thermo fuse has failed on the core plate, tells the freezer its cold enough to start blowing air, you can bypass it but not recommended. hope that helps, Russ
Jun 11, 2011 | True 72 cu. ft. / 2039 liter Commercial...
Missing plexi glass sign for my unit
These are referred to as 'signfaces'. I have one just laying around that says 'cold drinks'. I would suggest measuring it out and buying a piece of plexiglass from home depot, then going to kinkos and having them print out a similar size sticker to attach to it.
Jul 02, 2009 | True GDM-12 Refrigerator Commercial
We have a GDM-26 commerical coke machine. Only
If any of your drinks are freezing you need to adjust your temp setting. The suggested setting is 5. changing the temp setting basically tells the refrigerator to stop cooling when the temp hits a low degree, and to start cooling when it hits a high degree. This keeps your drinks not to hot, not too cold, but just right. If this doesn't work I would change the cold control altogether, it might've went bad. If you have a few minutes, locate the condensor fan (bottom) and make sure it is periodically turning on and off like it should.
Jun 08, 2009 | True GDM-12 Refrigerator Commercial
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
True GDM-12 Refrigerator Commercial Logo
411 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
