Question about Samsung SC-D23 Mini DV Digital Camcorder
What is the voltage, current, and polarity of the power supply for the SC-D23?
I bought a used Samsung SC-D23, no power supply. Although the power connector looks like it takes a strange rectangular connector, it appears that a standard barrel plug will fit it. However, I am unable to find any reference on the web or in the PDF manual that tells the voltage, current rating, or polarity of the plug. Could someone with one of these look at your power adapter and read these things from it? Thanks, Steve PS Yes, I know I can order a power supply from Samsung but I have loads of power supplies here. And I can't just buy a battery charger, since external power must be connected to use the Firewire port.
  • Steve Greenfield
    Steve Greenfield Feb 12, 2007
    But they want $60 for it! If I'm reading their website correctly (www.samsungparts.com), the adapter with square connector is $60. Is part number AD44-00065A? If so, I now know it's 8.4V at 1.5A. As long as my power supply is no more than about 8.4V, and at least 1.5A, it will work, but I still need to know the polarity.
    And they charge another $12 for the AC cord, it isn't even included.
    My plan is to fit a barrel connector to it, and epoxy onto the barrel connector to make it rectangular so it is less likely to shift and bend the center pin.
    I have switching power supplies from 3V to 24V. I am sure I can either find one that is 8.4V, or alter the voltage slightly on a 9V. I know not to use a non-switching supply, as the voltage varies to widely on them. A 9V transformer based adapter may go to 12V without a load, and under 6V under heavy load.
    Thanks,
    Steve
    Sniper:
  • 80 Answers
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Posted on Feb 12, 2007
What is the output voltage, amperage, watts and polarity for Schwinn 203 recumbent bike? I have a pile of transformers and don't know which one my mother-in-law used. Thanks for all replies.
If the recumbent digital computer gives you an option of power supply or batteries then you can deduce voltage of the power supply by counting the number of batteries needed times 1.5 (1.5 volts = voltage of AA or AAA battery).
You can deduce typical current by multiplying the number of batteries by: AA = .05 amps or AAA = .01 amps.
Your next issue will be to deduce the polarity. Look at the Schwinn to look for a symbol that will show you polarity. Typically the center of the plug is: + positive and the outer shell is - negative. There are instances where those two are reversed.
If this is all too confusing then Google the recumbent model number to find replacement power supplies ($35 to $45 US).
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Nov 28, 2014 | Schwinn Cycling
What is the power voltage for the x235 got display model dosent have a power lead
There should be information about that cast into the outside of the display housing, Charlie, or it may be printed in insanely small print on the serial number label. Most likely, though, it'll be cast into the housing near the power jack. It'll also indicate polarity, but it won't tell you which size the power plug needs to be.
If you can't find the voltage & current requirements anywhere but you CAN find the little polarity indicator, you could buy a "universal" power supply with switchable voltage and polarity. Start with the power supply set to the correct polarity and the LOWEST voltage. If it doesn't work, step up one notch and try again. Increase voltage ONLY until the unit functions, and NO higher. Tape over the voltage selector switch when you have it right.
Aug 04, 2014 | Exercise & Fitness
Where is the connection for the camera charger, on the camera and where can i get a manuel for my sc-d23?
You can download the manual from the manufacturer's web site at
http://downloadcenter.samsung.com/content/UM/200312/20031211083545640_SCD23-USA_FRA.pdf
Jul 29, 2010 | Samsung SC-D23 Mini DV Digital Camcorder
I have samsung sc-d23 but i dont have software cd for it..from where can i download the software
I have the same problem, (I am chilean (santiago) my inglish is very bad) if some body answer you , please contact me ... tedrosjct@hotmail.com. thank you
Sep 28, 2009 | Samsung SC-D23 Mini DV Digital Camcorder
When i try look though my video camera screen or even try recording it recieves no picture i have never dropped my camera and have always taken care of it so i do not understand why out of no where it is...
The SC-D23 is one of the Samsung camcorders affected by a recent class action suit. There is a manufacturing defect in the CCD.
Contact them via the number here to see about getting it replaced:
http://www.samsungclassaction.com/7.html
Jul 07, 2009 | Samsung SC-D23 Mini DV Digital Camcorder
Power supply for logitech driving force steering wheel
It's OK to use a power supply with a bigger current capacity than needed. If you find once with, say, 24V and 1.0A then that's usable - the wheel will draw as much as it needs.
Therefore:
Same voltage (24V)
Same or greater current (=>0.75A)
Same polarity (positive centre) __________________
Same as the Momo Racing Black, positive inside, negative outside.
The G25 power supply output is stronger: 24Vdc, 1.75A, same polarity.
As long as output voltage, polarity, amperes and connectors are the same you should be fine using a compatible unit, if you find one. In your case it would be 24V, 0.75A, positive inside, but if I were in you I'd wait for some American Driving Force owner to confirm this to be completely sure. The American psu model should however be GAD-SLU-240A8, 110V input, same PSU as Driving Force Pro. Take a look at this for more info. I received this from a forum with people that had the same issues as you and I hope this helps. It seems like they're saying that a store bought universal power supply may mess up your wheel so be careful. If this helps, please leave feed back. FIXYA!
Feb 14, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
Hi ..i have a samsung model scd23 and when i power on, on the lcd screen..its pretty disorted, cant get an image and when using the viewfinder, its jst white not picking up any images at all....
If your camcorder was made beween 2002 and 2007 you may be able to get this repaired for free. Samsung even pays for the shipping.
Go to www.samsungclassaction.com for more info
It worked for me
Dec 15, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
only problem is that your pc doesnt recognize your camera right?
try jumping from 1 usb outlet to another...
Mar 12, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
Samsung SC-D23 Mini DV Digital Camcorder Logo
138 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
