Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Fax message The result is TX(NG). Did it go through?
  • 65 Answers
No it did not. :(
The NG stands for no good.
Posted on Dec 05, 2008
I need to know if ny faxes were delivered even though I received results and comments such as NG, Cancel, OK, TX and TX,ECM.
The results your machine prints sometimes are only guides as to the conditions of the line etc, etc,....if you have to know with ABSOLUTE 100% CERTAINTY that the fax was recieved at the other end then you wil l have to call them on the phone, or send them an e-mail. and ask!!!!
Feb 26, 2011 | Brother IntelliFAX 2800 Laser Fax
Canon pixma mx 860, I try to fax and get msge NG #059 TX Canceled: RX Fax info mismatch What do I do?? Canon faxing has been one problem after another for me.
its a message from the modem in the fax
make sure the line is ok and he cable connected to the right place
if not helping than its better to send to service
Aug 23, 2010 | Office Equipment & Supplies
Trying to fax with pixma mx7600. Plugged phone
You probably want to plug the phone line (the line from the wall) into the port marked "L" for line on the back of the Fax machine. The jack with the picture of the telephone handset is for your optional voice phone to share the same line with the fax machine.
Apr 29, 2010 | Canon PIXMA MX7600 All-In-One InkJet...
NG result
NG is just the error and not the problem, you have to read the code with the NG, it could be a phone line problem, a problem with the fax on the other end, a busy or not answered fax...any number of problems.
Oct 09, 2009 | Canon LaserCLASS Fax 710 Printer
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Canon MP530 - Fax - ERROR TX Report - NG
Hi flyme.. I have the same problem but on an MF5770 all in one MFP. If anyone can solve this then wow.. I've been trying to find a solution for over 18 months now...
Jun 06, 2009 | Canon PIXMA MP530 All-In-One InkJet...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Jun 28, 2008 | Office Equipment & Supplies
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Sending fax
NG STANDS FOR NOT GONE , TYPICALLY THIS MEANS THAT THERE IS A COOMMUNICTION ERROR AND THERE IS ALINE DISTURBANCE /NOISE DURING THE CONNECTION WHILE SENDING THE FAX MESSAGE. TRY CHANGING THE TELEPHONE LINE IF IT IS AVAILABLE. HAPPY FAXING OMNIPRESENT
Oct 02, 2007 | Brother IntelliFAX 4100 Laser Fax
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,178 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
