Question about Promaster 7500DX for Nikon TTL Flash
Flash is not working with D70
Hello. I attached the Flash to the camera, turn it on as well as the camera, but it's not working. Help! What are the correct settings to use this flash with the D70?
5 Suggested Answers
bearydude
  • 62 Answers
SOURCE: I Have a Nikon d80 with a sb800 speedlight
CAMERA ON P , FLASH ON TTL , AND LENSE ON F22
WAIT FOR THE RED LIGHT ON FLASH , GOOD MEMORY CARD AND IT SHOULD WORK .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Posted on Nov 29, 2008
  • 70 Answers
SOURCE: metz flash 45 CT3 compatible with nikon D70
Call Nikon direct in Melville, NY or go to NIKONUSA.COM
Posted on Apr 20, 2009
SOURCE: sunpack pz40X II flash - compatible with Nikon D40?
Will myquantaray pz1 flash work on my
nikon D40x camera safely ?
Posted on Nov 22, 2009
  • 3 Answers
SOURCE: Promaster 7500 D Digital Flash usage with Nikon D70
you need to go to your cameras menu and set your flash function to m ( no to ttl) set it in full M and then it works hope it works that works for me i had the same problem
Posted on Oct 05, 2010
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
Sb600 flash has no communication with d70 camera
Have you tried using the wireless mode? Even if there is a problem with the hot shoe interface, it might still work using the wireless mode. To do this you have to set both the camera and the flash. On the D70, under the menu with the icon that looks like a pencil, select Flash Mode|Commander Mode|TTL|OK. On the flash, hold down the Zoom and [-] buttons to get the CSM menu. When you see the zigzag arrow, push the Mode button to turn on the wireless mode.You may have to use the [+] or [-] buttons to cycle through the menu to find the zigzag arrow.
Now you should be able to use the flash detached from the camera. Just pop up the D70 flash, which will tell the SB-600 what to do via light pulses. There are other settings that may be required (channel and group settings must match between camera and flash) and be careful not to block the light sensor on the side of the SB-600. If the wireless system is still working, you may find you like it better than hot shoe operation.
Dec 01, 2009 | Nikon Speedlight SB-600 TTL Flash
Quantaray QDC-NK i TTL Digital Flash Module
The Quantaray Digital NK Module has a small tab on the side of the raised boss that the 8 pins sit on that prevents it from mounting on the QTB-9500A. It's intentional- the NK Digital Module is made for newer Quantaray flashes only. You'll need the older-style AF NK Module to attach to the QTB-9500A.
Apr 06, 2009 | Quantaray QDC-NK i TTL Digital Flash...
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
Sep 26, 2008 | Nikon D70 Body Only Digital Camera
Nikon D70 flah not working, used to
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Feb 18, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 flash stopped working
Well, you are not going to like my answer. The troubleshooting guide for the D70 says it could be 1 of several PCBs (printed circuit board) being faulty or the connecting FPCs (flexible printed circuit).
You'll need to locate a local repair person or use the reapir service search here on Fixya. Nikon USA repairs will be $$$$
Feb 15, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Promaster 7500DX for Nikon TTL Flash Logo
93 people viewed this question
Top Promaster Cameras Experts
teddyboy
Lawrence Oravetz
Are you a Promaster Camera Expert? Answer questions, earn points and help others
