Question about Whirlpool LSQ9600L Top Load Washer
Washer sprays out when draining
We just moved into a new house. Our washer, a Whirlpool LSQ9200, worked fine at the last 2 homes. At this one, when it pumps water out the drain hose, the first blast of water sprays back up out the pipe. The rest of the water seems to pump fine after that. So, the drain pipe it about 52" high. It's normal size (2" pipe)... The washer drain line just barely reaches it, but according to the manual it's well within spec. So.....any idea what would cause this???
  • 87 Answers
You have a partially clogged drain or debree in the trap. You can try drano and a snake.
Posted on Jun 08, 2007
Washer fills with water but the timer is not moving
timer sticking if you can get at it spray the timer with wd40 penatrating spray or simmilar if that doesent work it the timer clock probably cheaper to buy a new washer than have this replaced hope this helps ivan
Sep 25, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
No water going thru washer arms
remove the pump screen and, clean the pump
you probably have broken glass preventing the pump impeller from moving
May 29, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Washer wont fill up, keeps draining
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
May 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
My whrilpool duet washer is flashing a error code of h and f
I found that my washer would not drain which is why I was getting the F02 code. I first pulled the strainer to see if it was plugged and it wasn't. I turned the little impeller to the right of the housing and it was free moving but it moved in and out as well as turned. That made me curious. I then to a shop vac and pulled on the drain hose at the wall hook up. It pulled and I could put my hand inside the strainer housing and felt the suction.
This led me to my last tought which was to pull the pump off the strainer housing. It only took three screws and when I pulled it I saw the impeller. When I pulled pack on the impeller it cam right out of the motor and I could see the end of the shaft had sheared and the grinding sound I heard was the shaft ends grinding and it was not able to move any water from the basin.
Im now looking for a new pump cause Im sure its one unit. So far they are over $100 for the complete housing and pump. Im hoping I can just find the pump.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer does not Spin fast
Is the drain hose blocked?
I had a wp washer and after moving into a new house we had a similar problem. I would come home from work drag the washer away from the wall, take it all apart and it would spin properly.
I'd button it all up and put it back in place and the next week she would complain again. When I was out of town she called the repair man. He came and cut 4" off the drain hose and the machine ran for another 10 years until the trany packed it in.
I guess the back pressure on the pump was restricting the transmission from spinning up to speed.
Mar 08, 2008 | Washing Machines
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LSQ9600L Top Load Washer Logo
104 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
