Question about Ricoh Aficio AP3800C Laser Printer
Resetfor ricoh cl3000
Firstable,because toner leaking all around the machine,after clean up then have message" set transfer belt unit or wast toner bottle" is there something I can do?
  • Everett Lin Jun 02, 2009
    This problem already solved, the problem is senser actuator broke.
  • 4 Answers
A bit vague there Bernu, this may be a novice to the copier world. The waste toner bottle is situated inside the front cover at the bottom left hand side of the machine. Simply slide it out, empty into a refuse sack, and re-install. This should hopefully solve your problem.
Posted on May 14, 2009
  • 161 Answers
Waste toner bottle lock
Posted on May 05, 2009
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Where is the trasfer unit on a Ricoh 3035 I have a message that says used toner bottle is full.....solution is to empty the transfer unit.....where is the transfer unit?
when you open the right door, the transfer unit is "brown belt", you need to remove it from door, remove belt, remove the screws and plastic cover and vacuum or clean the waste toner.
Hope that helps!
Apr 12, 2011 | Office Equipment & Supplies
Replace waste toner. what does it mean?
open the cartriage their are a waste toner in your cartriage cleane the cartriage then use
Oct 03, 2009 | Office Equipment & Supplies
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Waste Toner Light won't go off?
just clean out the transfer belt
Sep 20, 2008 | Office Equipment & Supplies
Ricoh 1035 Display Messages
Empty waste toner in transfer unit on the right side door.
Jul 03, 2008 | Ricoh Aficio 1035 Copier
Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 17, 2007 | Ricoh CL3000E Laser Printer
Ricoh CL3000 Laser, replace waste toner displar unit will not print, waste toner cartrige is empty.printer will not print? How do I reset unit?
Ricoh Aficio AP3800C Laser Printer Logo
353 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
