Question about Car Audio & Video
Renault clio i have ben trying 2 find the fuse 4 the cigarette lighter in my renault clio its a 1993 model which 1 is it
  • 194 Answers
Your owner manual should show you look in the index
Posted on Dec 05, 2008
Renault 2002 clio cigarette lighter remove and replace
Stop SMOKING and you will not need the lighter
May 28, 2015 | 2002 Renault Clio
Cigarette Lighter Outlet Doesn't Work; Fuse Still Intact
If the cigarette lighter has been in use for cigarettes ... it could be that the contacts within lighter outlet contact points are heat damaged and connection to auxiliary device may not be made electrically ... You could test if you had a voltmeter ... but if you can visibly see heat damage... perhaps you could try scratching any obvious tarnished metal contact point with screw driver... . (the central contact point is the one that is likely to be tarnished requiring cleaning) unless it is a loose electrical conection gone bad... but that would require removing the cigarette lighter.
Note: recommend to remove the cigarette lighter fuse before attempting to insert a metal object into the cigarette lighter... else sparks may fly and the fuse will/or should blow.
good luck.
Feb 27, 2015 | Volkswagen 2006-2010 Jetta TDI Steering...
What fuse is for cigerette lighter in 2009 megane privelige
the cigarette lighter fuse is usually the radio,clock ,instrument panel illumination fuse as well .If these other items are working ok i'd have to say the cigarrette lighter heat element is burned out or there is a loose /disconnected wire to the cigarette lighter socket
May 14, 2014 | 2009 Renault Megane 2.0
My 12v cigarette lighter socket keeps blowing fuses on my Renault Modus.
First step would be to use a bright flashlight and examine the socket (receptacle) closely for the cause of the short. You may be able to remove it. If the fuse blows when you try to use the cigarette lighter, the plug lighter element may be faulty and need to be replaced. These lighters are pretty standard and you could try one from another car that you know works properly to help diagnose.
Oct 02, 2013 | Cars & Trucks
My side light fuse keeps blowing on my 2002 clio. When this happens speado light goes off. Any ideas of how to fix?
Not really but i would check the bulb holders first ,rear light make sure its the right bulb ,look inside the bulb holder at the contacts ,one or two ?? check it out you would be surprised how many people fit the wrong bulb ,then if ok check the front light its a c?pless bulb and again the tiny contacts get bent and short it out .
Dec 23, 2010 | 2003 Renault 181
Hi, my cigarette lighter charger has been disconnected in my renault clio rn 98 and i cant figure out how to re connect it
How do you know the socket has been disconnected? I would suggest you first check the fuse that feeds this to make sure it has not blown.
Jul 30, 2010 | GPS
My renault clio dipped beam light are not nworking
itll be the light arm there allways going yes the swich has gon thanks ben
Nov 16, 2009 | 2006 Renault Le Car
Cigarette lighter
Call the Honda dealership. They should know where it is.
Jun 30, 2008 | 1993 Honda Civic 4 Door
Car Audio & Video Logo
486 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
