Toshiba Satellite C655-S5068 Notebook Logo
Anonymous Posted on Jun 27, 2012
No power or lights
I have no power or power lights on my laptop, with a.c. Adaptor plugged in, with or without a battery.
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Jun 28, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1186348
Points
16069
Sounds like you need to replace the laptop's power cord/charger.
2 Related Answers
Anonymous
  • 317 Answers
  • Posted on Jan 09, 2008
SOURCE: ac power light does not come on
if you want to be daring, take the CPU Chip, the largest one on the board out, and reseat it. this has to be done carefully, as to not break any of the pins. When you put the chip back in, pull the little lever up that the mount holds down, this will allow the chip to slide into the holder once it is in, gently push the lever back down, put be mindful of the amount of force that you use, then reattach everything, and keep your fingers crossed
Anonymous
  • 32281 Answers
  • Posted on May 02, 2009
SOURCE: Will not recognize AC POWER, Running from Battery only- now battery is dead.
The adapter might be faulty
Check the adapter with multi-meter, the voltage reading should be slightly higher than the voltage output that is printed on the label on the adapter.
My dv7 1245 dx had a short at the ac110 adaptor plug on the 18.5 volt end. This shut my computer down. Twisted wires. I bought a new HP adaptor. The computer will not power up now. The only sigh of life...
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
My laptop wont turn on. i also doesn't blink 3 times when i press the power button with the ac adapter plugged in. i tried taking off the battery and holding the power button on for 1 minute but that still...
Does the blue light come on at the side where you plug your ac adaptor in? If it does, and your laptop still wont turn on, its likely you have a motherboard failure. Also try this without the battery inside. If the light is not coming on the charger port at the side, then its most definitely your ac adaptor at fault.
1helpful
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
2answers
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
3answers
HP Pavilion ze2000 Laptop won't turn on
Have you tried removing the battery and seeing if the laptop will then run?
Compaq armada 7400 does not turn on
Please turn off the Computer and disconnect the AC Adaptor then remove the Battery. Next, try cleaning the metal contacts on the Battery and reseating the RAM modules.Then, connect only AC Adaptor to the Computer and try to turn it ON without the Battery. If the Computer doesn't turn ON then disconnect the AC Adaptor and insert the Battery then try turning ON the Computer. If the issue persists even after performing all the above steps then service will be required.
1helpful
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
2answers
Laptop won't power up
if there a battery, try to remove the battery and put the charger..try to check if the power come or not come.
second, if not come the power without battery..you must check first the charger output,working or not working..and third, check the power jack...thats the last...
1helpful
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Possbile battery
It could be a battery fault, have you tried it without the battery?
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
