Question about Acer Aspire 4315 Notebook
My Acer Aspire 4315 Can't Shut Down Normally
When i press start button-Turn off Computer, it will be to long time to shutdown, i have to shut down manually by pressing the power button. I using Windows XP OS, Whats the mistakes? is the bios not work (ACPI). i already check it but i didnt see menu for power (ACPI). what should i do now? Updating Bios or something?
Thanks for you answer
  • 2 more comments
  • HarrisYadav Dec 12, 2008
    my laptop has the same problem..I cant shut down my  XP OS on Acer 4315.Can anybdy solve this problem please..
  • pal_vijay12 Dec 19, 2008
    i cannot shut down my acer 4315 normally, i have to press the power button to turn it off.
  • Desktopsbyduck-Computers
    Question is your harddrive almost out of free space tell me what kind n model of computer.is the disk severally fragmented when was it defragmented last.how much memory do you have?if you aren't sure or confused i can help.Just need a little more info.but takes a long time how much time does it take?
  • HarrisYadav May 11, 2010
    I Come to know that the problem occurs due to web cam driver (Software) installed on my computer. On removing that software,I could shutdown my computer as normal as others. If somebody who has the same model laptop can adopt this ....
  • 81 Answers
That usually means a Windows problem (not hardware).
The best way to identify the issue is installing a fresh copy of Windows and all of the updates (I know is a lot of work) and see if still happening (i bet it won't)
Posted on Dec 15, 2008
My acer aspire one d255 won't shutdown. What should I do in order to shut it udown.Thank yo
keep the power button pressed for some time it would automatically shut down
Aug 17, 2011 | Acer Aspire One Netbook
I cannot shut down my computer when i press shut down my computer will restart.
To see if the problem is in the setting and not a hidden crash just type this command
SHUTDOWN -s -t 01
If with it the pc shuts down then go to Control Panel, click Power Options, click the Advanced tab. In the Power Buttons section, under “When I press the power button on my computer,” select “Shutdown.”
Jun 09, 2010 | Acer Aspire 4315 Notebook
Acer Aspire AS 3410, OS - WIN XP, shut down not work.
that means the drivers which you had installed is not working properly. u need to download the drivers of audio video & NIC card . check out the site. support.acer-euro.com/drivers/downloads.htm. make sure you have SP3 for XP.
Apr 12, 2010 | Acer Computers & Internet
I got problem with my acer aspire 3410, the system can not shut down normally. I always press little longer the power button to shutdown windows xp sp2. how to solve the problem? thanks if i use windows...
Hi there please try these mentioned below.
1. Restart the PC and repeatedly hit F8 until you have a menu in front of you.
77141c2.jpg 2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Apr 11, 2010 | Acer Aspire 4315 Notebook
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
The on switch refuses to close down the computer
Don't do that.
You should always try to shutdown by selecting it with the mouse. If you force a power down, you will eventually trash the operating system and files. But if you can't shut down normally, because the mouse it locked up or something, then hold the power button down for 10 seconds or so, to force a shutdown. It is designed to ignore the button being pressed for a short period by accident.
Jan 01, 2010 | Acer Aspire One A150-1006 Notebook
I am having a memory problem with my Acer Aspire One.
Since you forced your computer for shut down it does not save settings as it should at the time of shut down.. Check your seeting as everytime you don't properly shutdown your PC this problem will occur...
Oct 28, 2009 | Acer Aspire One PC Notebook
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Laptop won't shut down normally!
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
Oct 31, 2008 | Acer Aspire 5630 Notebook
Acer Aspire 4315 Notebook Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
