Question about Kitchen Ranges
JGD8430ADS jennaire ignighters keep clicking after being lit, also all click even though only one is turned on Thank you for any assistance
    Habit-Forming:
  • 171 Answers
The wires to the igniters are wet.Or a wire is maken contac with the metal of the stove those 2 problems will give you the same problem. if wet turn on the oven for an hour, to dry it.
Posted on Dec 06, 2008
5 burner gas Vicking stove top keeps clicking after is on
Their are 2 possible reasons the igniters would continue to click after the burner is lit.
1) the burner is slightly dirty and the part of it very near the electrode is not burning correctly so the igniter doesn't think the burner is lit so it will not tell the spark to turn off. It could be cleaned by using steel wool and cleaning the burner holes near where the electrode is and then use a paper clip and poke through the holes on the burner to clear them so they burn correctly.
2) the electrode (the spark plug at the burner) is cracked so even though the burner is lit so the electrode can not sense that the burner is lit and wont tell the spark to turn off,so if having cleaned burner it still clicks after burner is lit the electrodes would need to be replaced.
GENE
Oct 08, 2011 | Kitchen Ranges
Ignighter workis and burner has flame but will not keep burnner lit. speed queen dryer. made by RAYTHEON
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 06, 2011 | Dryers
I have a Jennair model ccg2423 stove top.Only one burner ignites yet the clicking sounds seems heard on all 3 others
Hello, Thank You for using FixYa. I will be helping you today.All four ignitors will spark even if only one is turned on.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Igniter misfire
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Mar 25, 2010 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
I have a Jenn-air gas range that is suddenly making a noise under the center exhaust fan even though everything is turned off. It sounds like rain hitting metal. When I put my ear down closer to listen, I...
Is the exhaust clear all the way out? Unplug the range and see if the problem goes away, if so you may have a control problem that is keeping the fan operating at a very low speed.
Good Luck,
Gilshultz
Dec 03, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Jun 21, 2008 | Stoves Premier 720GRa Gas Double Oven
Dryer Ignitor turns on then back off with no flames afterwards
the government mandated that gas appliances start using electronic ignighters because pilot lights would keep blowing gas even after they blew out now the way they work is calibrated on how much amps the glow bar draws the rest of the amps go to the safety valve to open it when the glow bar is drawing enough amps to be hot enough to ignite the gas now what this means is even though the glow bar glows it can still not be hot enough to ig night the gas so the safety valves don't get the right amps to the solenoids to open so you could have a weak ignighter or bad solenoids on the safety valves now i would lean toward the solenoids but i would buy both and first replace the solenoids then the ignighter if the solenoids work take the ignighter back
May 22, 2008 | Kenmore 74602 Gas Dryer
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
