Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Washer spin problem
Once the washer starts its cycle it agitates the clothes like it should but once it stops and then begins its first spin cycle the motor sounds like its trying to spin the drum but the drums not spinning. If you lift the lid momentarily and let it close the drum then spins and the water drains normally. The sound of the spin cycle changes when its draining and spinning too.It sounds like a belt is turning but just slipping on the drum pulley but with no smell of burning rubber. This problem occurs 3 or 4 times during the complete cycle. If you have any idea whats going on or how to fix it, it would be greatly appreciated
  • samsonthedog Jan 15, 2008
    I have the exact same problem, including the same hot electric/rubber smell. The drum seems to turn when it's full of water, but once it starts draining and when it should spin, it's not. And it's not because it's overloaded or the clothes are all on one side.
  • Anonymous Jan 12, 2009
    I have the same problem. A "certified" repairman told me it was the timer. He changed it and I still have the problem. I know it's not the amount of clothes cause it happens whether I have 1 piece of laundry or 6. I'm trying to find a repair manual to do it myself but I can't seem to find one. Any other thoughts? I also have a problem with spinning in general. At the same load, the spin cyle is nice and strong at one point then extremely weak at another. When it's weak, it sounds like theres something loose, a light metal to metal sound. Any thoughts?
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Posted on Feb 12, 2007
Maytag centennial washer
Most likely pressure sensing switch. What is your model #? If your model has this part # W10292584 then it is the problem.
Nov 11, 2017 | Washing Machines
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is making a clicking sound when it is about to begin the high spin cycle to spin the water out of the clothes and is unable to begin the spin cycle on it's own. I have to manually move the knob...
If this is a belt drive unit it could be the belt or whats called a actuator also call a shifter. This componet switches the gearbox from agitate during wash to Spin to extract the water from the garments.
Happy Holidays
Nov 21, 2017 | Whirlpool LSQ9500L Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
206 people viewed this question
Sal De
Marvin
Marvin
jimorris77
