Question about Hand Tools
Where to buy accessories for my Multimaster Tool
I bought the Fein 6-37-06-012-02-4 Fein Diamond Blade.
Where can I buy accessories such as screws & frame for this particular blade so it can be fitted on my Multimaster tool.
    Problem Solver:
  • 17 Answers
Www.feinus.com try them.
Posted on Dec 12, 2008
The rotary speed dial in my Fein MultiMaster slips caused by the vibration when the tool is turned on. Is there a way to tighten it?
No way of tightening its a variable resistor molded in to Electronics. Would try get a warranty replacement if its close to any of the warranties they offer. Its One year normal or Three years free extended World Wide Warranty. Would recommend anyone buying FEIN to extend it free within four weeks of purchase.
Aug 17, 2014 | Fein FMM250Q Select Multimaster...
Fein multimaster
interference suppression capacitor or electric field .
Apr 19, 2014 | Fein FMM250Q Select Multimaster...
FEIN FMM250 NOT WORKING
Check Cable Or Brushes. while tool is not plugged in to wall socket unscrew three 15T torque screws check cable with multimeter for open wires look at brushes pull out of holders.
Sep 11, 2013 | Fein FMM250Q Select Multimaster...
Tool blade will not vibrate
41701241126 a bearing in front of the machine OR THE MACHINE HEAD be aware of the price , there are no parts to get only the complete head 31508260010 its not worth to repare because of the budget prices oft that this tools are to get in that last case of defect.
Sep 01, 2013 | Fein FMM250Q Select Multimaster...
Fein multimaster repair shops/centers????
Wow, I don't have a multimaster but I want one. I know they make two kinds. One that's 700.00 dollars and one that you can get at the hardware store. I'm beginning to think there might be a problem with the switches in this thing. Go to eReplacementParts.com and view the schematics to order a new switch.
Dec 19, 2011 | Fein FMM250Q Select Multimaster...
Fein multimaster 250Q quick release not working. Spring action worked at first when lever was fully pushed (180 degrees) the tool holder would not release and the spring action was gone. How doe I fix...
either your not holding the pin in the right place or your multimaster was used with the pin in the wrong place to begin with and the lever was forced down causing the holding mech. to wear out.
Oct 21, 2010 | Fein FMM250 Start Multimaster Oscillating...
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Fein multimaster sanding attachment broken
Pretty sure things like that are considered expendable. Pat yourself on the back for getting so much sanding done and buy a new one.
Sep 26, 2009 | Fein Tools & Hardware - Others
Blades wear out quickly for the high price of the blades
Joa-liff@hotmail.com supply a range of adaptors to fit the fein Multimaster and Supercut machines that allow you to use both Bosch and Multimaster blades. hope this helps.
Mar 28, 2009 | Fein Supercut with Carpenter Kit - FSC -...
Hand Tools Logo
152 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
