Question about StarTech.com StarView SV211K 2-port KVM Switch
Box just wondering if i`m putting code in correctly i go to menu then parental control press info button and my pin which take me into the section where you go to switch your emu on.i go to the navigation menu and put codes in for 00 and 01 and storing them when i complete the codes.Then i exit and when i go on the cable channel it comes up updating data and just keep updating.Should it come striaght on if the codes are correct. Thanks
  • igb_41 May 11, 2010
    yes it should come straight on ntell are in the top box on code screen ?
    Problem Solver:
  • 12 Answers
Don't bother going into parental control, just press menu ( install,parent cont, factory sett etc ) & punch in 1570 & go into nagravision, then punch in relevant codes, ok ?? hope this helps 00--3f b8 36 62 72 e5 e2 76 & 01--35 5e d6 40 6e aa 99 41 ( nthell )
Posted on Dec 05, 2008
I need a pin code for a Toshiba tv. Please
hi Cheryl.
Press the "MENU" button, select Prefer, highlight Parental Control and press the right arrow key or menu button to enter the PIN code entry screen. 0000 is the default password. When the correct PIN # is entered the Parental Control Menu opens and you can change your settings and PIN code here.
Changing the TV password
or read up some more at this manual.
Toshiba 19L4200U User Manual Forgotten Pin Code Changing Or Deleting Your...
or this one.
4 digit pin code for toshiba tv Google Search
Dec 17, 2017 | Toshiba Televison & Video
How to reset parental control for wiiu
While on the Wii U Menu, press the HOME Button.
Check that the Wii U console's date and time settings are correct. ...
From the Wii U Menu, select "Parental Controls."
Tap "I Forgot" or press the X Button.
Answer your secret question or tap "I Forgot." ...
An inquiry number will be displayed on the Wii U GamePad.
http://en-americas-support.nintendo.com/app/answers/detail/a_id/1078/~/forgot-parental-controls-pin
Dec 24, 2016 | Video Game Consoles & Games
Master key for parental control
  1. Navigate to the Wii Menu by pressing the HOME button on a Wii Remote and selecting "Wii Menu."
  2. Look at the date and time displayed on the Wii Menu and ensure they are correct. If incorrect, they will need to be changed in order for you to complete the PIN reset process. You will not be able to reset the PIN until the date is correct.
  3. Select the Wii Options icon in the lower-left corner of the Wii Channel Menu.
  4. Select "Wii Settings."
  5. Click on the blue arrow to reach the Wii System Settings 2 menu options.
  6. Select "Parental Controls," then "Yes."
  7. Enter your PIN or select "I forgot."
  8. Answer your secret question or tap "I forgot."
    • If you know the answer to your secret question, enter it to unlock parental controls. The system will go to the change parental controls screen and you will be able to change your PIN.
      • Be sure to enter the secret question exactly as you originally typed it, as the answer is case sensitive.
    • If you don't know the answer to your secret question, tap "I forgot."
  9. A screen will appear showing you a request code.
  10. With that request code, you will need to do a request that involves charging US$0.50 from a credit card, to confirm that you're an adult. Or should your kids try to circumvent your parental code, it will show up on your credit card bill.
You can request the reset here:
Parental Controls PIN Reset Nintendo Support
If you need further instructions on how to do that, simply look here:
Forgot Parental Controls PIN Wii and Wii mini Nintendo Support
Mar 04, 2015 | Nintendo Wii Console
Parental cantrol
Or get a more detailed step-by-step instruction here:
Forgot pin code for grundig gud300hd freeview hd box
Ok this info does not seem to be anywhere so here goes.....
Grundig gud300hd and others of same build alba ect...... set top box pin reset
UNLOCK CODE1. Press MENU and go to Settings and press OK.
2. Go to Parental Control and press OK. The 'Enter the PIN Code' menu will be displayed.
3. Press i (information) button once then enter 4000.
4. Go to Change PIN Code and press OK.
5. Press i (information) button once then enter 4000.
6. When it prompts for New PIN enter the desired PIN number using 0~9 keys. Enter it again to confirm.
hope it helps
Nov 24, 2012 | Grundig Televison & Video
My son blocked everyone out of the tv with parental control. He can't remember the password he used and I can't get the reset to do anything. How can I fix this?
If you have reset the TV back to factory settings, you can use the factory unlock code, which is 0000.
To Reset the TV:
  1. Press the MENU button on the remote control to display the Main menu, and select SETUP.
  2. Highlight Reset Default, and press the OK button.
To Remove the Parental Control Block:
  2. Highlight Parental, and press the OK button.
  3. To use the Parental function, must enter a four-digit password. The factory password is 0000.
  4. Select Program Block, and press OK to display the Program Block menu.
  5. You can remove the parental control in this section.
May 25, 2011 | Polaroid TLA-01911C TV
Cant set parental control on my sky hd tv. why?
Are you referring to the Sky T.V. box ? If so, do the following.
How do I set up parental controls?
You can set up parental controls using your Sky remote control. If you want to turn the PIN restrictions on or off at any time, go to the Parental Control menu (press the services button to access this) and press the red button.
Hope this helps, ~Don
Feb 28, 2010 | LG 47LH40 47 in. LCD HDTV
Philips freeview digi box dtr1500
thanks my daughter solved the problem to unlock parental lock or parental pin number she tried four zero digets 0000 no success then she put in four numbers one 1111 and it unlocked the parental lock .hope it can maybe help someone - margaret
Oct 01, 2009 | Philips Universal PH301S Remote Control
Need CODE to get second pin up on starview 2(THE BOX PVR)
You enter 1570.
Fixya!
Chris (ziraffa)
ps To put keys in manually do as follows.
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Jan 14, 2009 | StarTech.com StarView SV211K 2-port KVM...
Parental control
1. Go to the V-chip selection in the customer menu.
2. If the set has an active PIN code, the menu will display “BLOCK-ING ACTIVE”.
3. Press RECALL on the remote four times within five seconds.
4. The menu should then display “BLOCKING RESET”.
5. Input a new four-digit PIN code and press ENTER.
6. The next menu page will appear which allows you to scroll down to the various lock selections. If you want to remove the PIN code completely, instead of entering a new code, just exit the menu after pressing recall four times.
1. Disconnect AC power for several seconds to reset unit clock.
2. Adjust unit volume to minimum.
3. Press and hold volume down button on unit control panel.
4. While holding the volume down button, press and hold the “Zero” key on the unit remote.
5. The user menu will appear with the V-Chip cursor blinking.
6. Pressing the “Enter” key on the unit remote will open the “New Password” menu.
Have a great day!!
Bill
Dec 09, 2007 | Toshiba MV13L3 13 in. TV/VCR Combo
StarTech.com StarView SV211K 2-port KVM Switch Logo
49 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
