Konica-Minolta DI-2510F Displays code C0500
Customer explained that the Code C0500 displayed after a paper jam was removed from the machine.
Everything checked seems to work fine but the code will not reset. I don't have a Service Manual for this particular unit. Is there a way of trying a Service Mode reset? What is the password (default) for entering the Service Mode and how do I get there?
Thank you for any suggestions.
  • 2 more comments
  • gpk1952 Dec 11, 2008
    Immediately after the soft init is pressed the display changes to "Please Wait..."
    After about a minute the screen changes to the initialization screen (the one that displays when you first power up the machine).
    Pressing the #3 key does absolutely nothing.
    Pressing the "Utility" key brings you to a screen from which you can access "Maintenance Mode". Pressing this button on the screen brings up another screen that requires a password. I've tried several normally used combinations of 4 to 9 numbers but nothing works. Would be great to know what the factory default code is.
    Thanks for the help so far.
  • Anonymous May 07, 2009
    code
  • Anonymous May 08, 2009
    incident detecte .appeler le S.A.V et indiquer le code affiche ci-dessous
    c0500
  • naoual Sep 14, 2013
    Guest incident detecte .appeler le S.A.V et indiquer le code affiche ci-dessous C3451
  • 145 Answers
Solution:
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.{IT A SMAL HOLE THE SIZE OF PAPER CLIP IN DIAM-U CAN USE PAPER CLIP
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
GOOD LUCK
Posted on Dec 06, 2008
  • sam gerban
    sam gerban Nov 29, 2009
    the default password is usualy 8 zeros or 12345678
  • zaheed muhammed
    zaheed muhammed Feb 15, 2014
    code:c0500. minolta cs pro ep 3000,how to reset..........
    New Friend:
Guest incident detecte .appeler le S.A.V et indiquer le code affiche ci-dessous c3451
Posted on Sep 14, 2013
HOW TO SOLVE ERROR CODE C0500 FOR KONICA MINOLTA 211
Error code C0500 and C0501 means Fixing unit's temperature abnormality.
How to reset these codes?
To reset Error codes C0500 and C0501, perform the following steps.
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
http://servicekonicaminolta.blogspot.com/2012/03/error-code-c0500-and-c0501.html
Jun 14, 2017 | Konica Minolta Office Equipment & Supplies
How can I reset eror code CO 500 on konica minolta copier DI 2510
Aug 08, 2016 | Konica Minolta Di2510 Di251 Di250 Di2010...
Maintainance call display of konica minolta copier bizhub 211
Maintenance call? from your question it is not clear what is the error code.Please see if there is any code appearing besides maintenance call.Note the error code and tell me again so that i can help you.If it is C0500 or C0501 then press the stop button on the panel and restart the machine do not release the button until the code removes.
Dec 13, 2012 | Konica Minolta KONICA BRAND TN-211 BLACK...
Di minolta 251 diplays the code c0500 if when the wires are connected properly and sufficient current is supplied. What do I do to correct it? Thanks.
Check Your Fusing unit. if there is any possible changes on it maybe wires wer cut off, or some pieces of paper left inside of it (fusing unit) blocking the thermostat or just simply buy an AVR.
Dec 08, 2012 | Konica Minolta Office Equipment & Supplies
Call for servce code c004e
Its a failed Power Supply Cooling Fan Motor. Replace the cooling fan with part number 111T80010.
Dec 11, 2010 | Konica Minolta Bizhub c203 Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
I have a problem whith minolta dualta di200,the problem is "error code c0500,can somebody help me?
C0500
The temperature of the Fusing Rollers does not reach
the required level even after the lapse of a given
period of time during a warm-up cycle.
There should be a small opening or hole on the right of the operation panel, use a paper clip to press the button inside. This will reset the machine. If the error code was a glitch or a false code the machine should operate. If the code comes back you will need to have a technician replace the fuser assembly
May 14, 2010 | Konica Minolta DiALTA Di200 Copier
Machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Sep 13, 2009 | Konica Minolta bizhub 180 All-In-One...
Error code C0500
C500 is a fuser code, the hot part of the machine, the fuser fuses the toner to the paper, so that the toner does not smear off. But to solve this must have the model number. As each series of machine has a different way to reset machine
Jul 21, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
1,913 people viewed this question
jasbo
jasbo
