Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
Panasonic cs-pw9gke i need wiring diagram
Hi i need wiring diagram for cs-pw9gke split a/c, i want to know how many cables you need to connect the indoor with the outdoor unit.
CLIMAINVEST FROM RODOS GREECE THANK'S
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Posted on May 02, 2009
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
Where is the infrared receptor card in this equipment to change it. I have a split ac panasonic CS C24BKP and does not respond to remote control. I know the remote control is good because I saw thr...
There is a receptor on the below the front pannel but the problem could be :
1.Low battery charge in the remote control.
2.The signal cable that connects the receptor to the card(pc board) could be loose/disconnected
3.Try one receptor from a working unit
4.Try a remote control from a working unit
Regards,
Adamson
nyauadamson@gmail.com
May 02, 2014 | Heating & Cooling
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
Control cable wires crossed
I would not do anything just yet It might be more prudent to call Panasonic help line, and explain your findings I feel that the system will not have suffered any damage if the control cables have been simply wired incorrectly if that is the problem, try and find a call number from your installation paperwork, good luck.
Jun 08, 2009 | Heating & Cooling
Have a near new panasonic cs-e28hkr split system air conditioner and the outside condensor fan continously runs even with inside unit is turned off? Thanks
Sir/madam,
If the inside unit (evaporator) is turned off absolutely.
The condensing unit must be turn off outside because the power
are derived comes from the evaporator.
Possible it seems on the cut out stage inside and remain the power still on
Otherwise theres somebody tamper the connection?
Fan cable consist of 3 wires
1 Common line
2 Start /stop line***Change the connection of this wire where it located, To On/ Off switch of the
evaporator inside unit
3 Ground green line/Earth
note: you can get all that wires inside the power supply in evaporator area.
If still under warranty inform the manufacturer
r_ic7
Nov 29, 2008 | Panasonic Heating & Cooling
How do you set a samsung ide hd to master mode
To set a Hard Disk to master mode is quite simple. On the side of the Hard Disk that has the power hook-up and data hook-up, there is also a small section of usually about 8 little prongs, and you'll see something that looks like somebody stuck something on those prongs. It is called a jumper, and it can put the hard disk in various states such as Master, Slave, Cable Select, and more. You usually cant use a hard drive without a jumper, so don't lose it. On either the top or bottom of the HD, there should be various information about the HD. You should also see a diagram of about 8 squares, just like the 8 prongs next to the power and data connections on the HD. Find the one for Single or Master, switch the jumper to the position it tells you to, and you'll be all set!
Apr 13, 2008 | Computers & Internet
Salvage Job
This should not be a problem. Cut off the plug off the wire oppisite the sub connection. Turn on the sub and touch each wire till you hear a buzz, that should be your source wire. Connect up an RCA plug with the ground of course, and you should be set. Good Luck
Jun 28, 2007 | Panasonic SC-HT17 System
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
816 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
