Question about Audiovox Hands Free Headset for 9100 Headset
Programming required my sister was playing around with the phone, and now it says on the screen PROGRAMMING REQUIRED. i cant figure out what to do
0 characters
1 Points
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
On the User ' Button Programming tab select and double-click on an available
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
My htc phone cant find my samsung wep460 bluetooth
Try to put your headset in pairing mode, prior to trying to pair it with your phone. If it has never been paired with another device defore, just by turning it on, it should enter that mode, denoted by its indicator light being steadily lit in blue. Otherwise, turn your headset off. Then, press and hold the Muiti-Function Button for far more seconds than the time required to turn it on, until its indicator light is steadily lit in blue. Then, within the next couple of minutes, bring your phone and headset close to each other, and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make your phone connect to it. If a pairing code (or PIN, or passcode) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There should be an indication on your phone too, that the pairing process has been successful. Otherwise, turn you headset off and repeat the pairing process all over again.
Hope you are able to sort your problems out soon. Anyway, please, let me know if I can help you any further.
By the way, if your headset's quick start guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Mar 13, 2011 | Samsung WEP460 Bluetooth Headset
Bluetooth connection
Ensure that your phone is switched
on and the headset is switched off.
2. Press and hold the power key until
the green indicator light starts to
flash quickly.
3. Activate the Bluetooth feature on
the phone, and set the phone to
search for Bluetooth devices.
4. Select the headset from the list
Feb 09, 2010 | Nokia BH-208 Wireless Headset
Upon starting up phone;red strip at bottom states"Unlock". Also,states in screen "Initial programming needed". Bought at a swapmeet,looking to service...
you should be able to press one of the buttons under the word unlock to unlock it then to program it you will need to pair it the phone the phone has a bluetooth menu which will say discoverable or something to that effect visible press it then put the hands free in pairing mode by pressing the button under pair or sometimes holding down the button til it says to pair or gives a strange series of beeps depending on the model then on phone hit serach for devices and thenit will ask for a password on both type 0000 and then its set up you can toggle on and off through the hands free option in your phones menu or if by any chance it gives a dial pad dial *228
Jan 29, 2010 | LG VERIZON VX5200 Hands-Free Headset...
Help in playing music to my Samsung blue tooth.
Unfortunately most phones cant use the bluetooth headset to play music thru you will need to purchase a set of bluetooth stereo headset (headphones) like these 35490aa.jpg
Google Search: Bluetooth Headphones
Jan 03, 2010 | Just Wireless Bluetooth Headset Wireless...
Cant open any messages sent to my phone inbox
You need to check the settings then .....
Message > Menu > Message Setup. Fill in the required and you should be away.
Master Clear and Master Rest get rid of all your pictures, ringtones, videos and address book
so beware of this !
Aug 06, 2009 | Motorola Mobility HS850 Consumer Headset
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Mar 18, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth wont sync with my bluetooth enabled phone
This is not actually a solution, but when I had the same problem with my Jabra (which I think is one of the best), I took it to my phone store and they synched it for me. Lots of navigating around and knowledge of a code to input. Screw it, let them do it!
Dec 20, 2008 | Jabra BT350 Bluetooth Headset Headset
Motorola razor (IMEI: 354099/01/122588/9)
Sorry no, to unlock the company / service provider lock you will have to find either a person with the tools required (that would make it free) or then use a public website which offers these services for a small fee. is one of them.
I don't have the software / hardware required to perform these unlock code calculations.
Jun 18, 2008 | Headsets
My screen is messed up
The lcd display screen resister is damaged, unfortunately you need to replace your phone.
Aug 24, 2006 | Motorola Mobility T-MOBILE V360 Flexible...
Headsets Logo
23 people viewed this question
Top Audiovox Headsets Experts
Brian Sullivan
Brian Sullivan
Are you an Audiovox Headset Expert? Answer questions, earn points and help others
