Question about Maytag Neptune FAV6800AW Top Load Washer
I HAVE WATER DRIPPING INTO THE TUB FROM THE RINSE SPROCKETT
THE MAYTAG WASHER I HAVE IS A MEDIUM RANGE MODEL ABOUT 10 YRS OLD. WATER IS DRIPPING FROM INLET AREA THAT PROVIDES FILL AND RINSE WATER.
IS THIS DO-IT-YOURSELF FIX OR SHOULD I CALL A REP?
THANK YOU.
RON
CONNECTICUT
  • James Raymond Williams
    James Raymond Williams May 11, 2010
    Is the water coming from the flexible hot and cold pipes that connect to the back of the washer?
    Genius:
  • 1,199 Answers
Hot or cold? the water inlet valve may be cracked or lose...not that hard if you are a handy person!
Posted on Dec 09, 2008
Washer tub fills after wash is done; hours after! 4-5 inches of water the next day
http://www.searspartsdirect.com/part-number/205613/0026/464.html?modelNumber=LAT9593AAL&categoryName=Residential%20Washers&brandName=MAYTAG
This is the water valve your model calls for.
Sep 24, 2017 | Maytag Washing Machines
I HAVE A MAYTAG PERFORMA WASHER MODEL#pav3240. the washer continues to fill during rinse cycle and overflows the top. If i turn to spin cycle water drains out and machine goes through cycles. it seems like...
Clean out the water-level switch air dome tube AND the the connection to the tub where the tube connects. It may well be full of gunk and not allowing the water level switch to react quickly enough.
Jun 06, 2017 | Maytag Washing Machines
Maytag washer LAT9334AAM aprox 14 yrs old. Have
Are you using a liquid fabric softener ? If so , try using dryer sheets instead . Maytag is known for making liquid softener look like grease on clothes . After switching for a while , and still grease looking stains , then it is possible for the water to be getting into the transmission and pushing the grease up into the tub . Rare , but happens . Time for another machine if that happens .
May 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Dripping water into tub
seems to me that there is something holding open the valves. you can take the hoses off the back (turn off the water first, naturally) and see if there is a lot of buildup inside the valves. There are screens in there that you could take out to inspect inside the valve from that side, perhaps you can see something there holding it open. If there is nothing you can do, you may have to replace the valves. Not sure of cost but shouldn't be too costly.
Sep 01, 2009 | Whirlpool LSR5132PQ Top Load Washer
Dial doesn't advance to next cycle
if u can advance it manually and it works u need a timer if not probably a lidswitch
Mar 27, 2009 | Maytag Washing Machines
GE Top-loader Leaks Water from Vertical Tube Behind Tub on X-Large Loads
it sounds like the basket is not locked when it is agitating, if so the water will climb the wall during the wash cycle and leak out of the overflow (which is the plastic tube you described). if this is the case, it is a transmission brake problem. it can be fixed by a professional, but you might want to look into buying a new machine.
Jun 18, 2008 | GE WHRE5260E Top Load Washer
Maytag Insignia hot water dripping only (5 yrs old)
sounds like the diaphram in the water inlet valve is going on the hot water side. you need to replace the whole valve. turn off water and remove hoses. remove the housing that holds the valve and remove the valve. replace and reassemble.
Apr 07, 2008 | Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
