Sharp CD-BA 2650 Error code: ER-CD 11 - the CD tray will not open
I have a Sharp CD-BA2650 3 cd, two tape deck, and radio combo. Every time I try to eject the CD tray it gives the error code ER-CD 11. I cannot play CDs anymore in it. Anyone knows what this error code is and how to fix it? Your help is really appreciated. Thanks in advance.
  • amasar1 Jan 02, 2009
    Mine too--it's making a rattling noise as well.
  • Anonymous May 17, 2009
    me too
I had the same problem but fixed it by replacing the cd belt which was broken and relined the main cd plate which holds cd to correct position . and god fixed it.
No more errors and now a great cd Hi Fi.
Make sure all s aligned and blow out all dust with an blower or air compressor.
I pull the top plates off blow air into them and replaced a broken belt for cd's and not it's new machine.
You want to fix it than fix at the source.
Posted on Jan 08, 2011
I had the same problem. my brother took it apart and found that the belt that opens the tray was snapped. he bought a new one at radio shack and replaced it. but now there's a new error with no code. so thats as far as i can get you. sorry. =)
Posted on Apr 15, 2009
Cd tray will not open er cd11 code
Just talked to customer service at Sharp because I had same problem with my CD trays getting stuck and would not open even if they had cd's in them. He walked me through resetting the cd system. First have unit plugged in but in standby/off. Then press the open/close button, the stop button and the CD button all at one time(beside holding unit still to keep from sliding) till the display flashes CLEAR ALL and then let go and turn unit on and see if it solves your problem. It solved mine but I did write down instructions to make sure if it happens again I can use it again. Good luck, Helen
Jan 03, 2014 | Sharp HE CDDH950P Mini System
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
HTH
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
Olds 98 radio error E22 and E23.
Just found this... doesn't help me since I'm using the tape deck and not the CD part... E22 : Motor Error Cause(s): The CD motor is not handling the compact disc properly. Correction(s): Service or exchange the unit at an ACDelcoã‚â® Service Center.
Mar 13, 2009 | 1995 Oldsmobile Ninety Eight
The cd trays will not open, giving me a er-cd 11
youhave to check the all whole mecanisum to find ths prob.
nuwan.
Jan 14, 2009 | Sharp XL-DK225 Shelf System
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
I have a Sharp CD-BA2650 3 cd, two tape deck, and radio combo. The Cd turntable sticks when one cd ends and changes to the next. The rotation stops as the motor makes a humming noise, then the lcd says...
There is a belt inside the cd changer that needs to be replaced. Once yo utake the top off the unit you will need to turn the unit on again and open the try. Once it is open look at the back area where the motor is located and you will find it under a circuit board. You need to lift the motor up by pushing the plastic clips that hold the board in place and pull it up a little and you will see how the belt is on the pully. It is very hard to describe how to do this in a forum like this, but if you are careful you should be able to do this.
The part number for the belt is:
92LBE231616
You can get the belt here:
http://www.fox-international.com/
I hope this helps, if so a FixYa! rating would be appreciated. After all, it is the only reward we get for offering people like yourself this free help.
Let me know if I can be of any more help.
Dave
Nov 02, 2008 | Sharp Audio Players & Recorders
Error code 0203
This is a mechanical error. The mechanism is stuck and can not reset to a known condition. Look to see if a CD has slipped nad try to get it back in place. If that is not the case, it will need service as the mechanism is now out of timing.
Dan
Mar 26, 2008 | Sharp CD-BA2600 CD Shelf System
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
2,052 people viewed this question
 Grubhead
Grubhead
