Each time i try to turn on my Toshiba Satellite L305 ( laptop), the on light goes on, but nothing else happen's, the hard drive light does not flicker and the screen stays black. The airport light usually turns on when I start the computer, but this time it didn't, I tried turning it on and off but nothing happened. I also tryed turning my computer on and off but then still nothing happened, can u please help me? Thank you very much.
I had a similar problem but with a desktop and the subject was a component (memory) wrongly connected.
You can check if you have any pcmcia or maybe a memory card not right plug-in.
Posted on Dec 05, 2008
  • 61 Answers
Removed the power conection and remove the battery as well and press and hold the power button for 5 to 7 sec and then connect the battery and power cable and try to turn on
Samson Ved
Automatic restarting the laptop after few idle time. Sometimes screen goes to green. Problems of my toshiba l305-s5933 laptop
Power Cells may be defective. Check the Memory also. Have the Hard Drive tested, boot sector could also be compromised.
Feb 02, 2014 | Toshiba Satellite L305-S5933 (4400 mAh)
How to upgrade a toshiba L305 to a 500gb hard without hardware failure error
I'm a bit confused? You are trying to install a HDD with Windows 7 on it from another computer in a Toshiba L305 laptop? If that's correct, it will not work, first, you must format the 500GB SATA HDD, then load the Windows 7 OS to get a clean install. Clarify the question if I am incorrect.
Jul 03, 2013 | Toshiba Satellite L305-S5875 Notebook
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
Toshiba Satellite L305-S5907 15.4" Widescreen Can
With the Toshiba Satellite L305-S5907 Laptop, you can put a 500GB hard drive and up to 2 TB hard drive. The only requirements are to make sure it has a SATA connector and is 2.5" Size. These are very common and easily found online. For example, here a 500GB one that is compatible that I found: Click Here.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 24, 2011 | Toshiba Satellite L305-S5907 Laptop
The screen on my Toshiba Satellite L305-S5933 PC Notebook suddenly got very dim, to the point that I can barely read/see anything. I tried adjusting the brightness in control panel; the slider is all the...
Probable inverter board failure; this supplies high voltage to the fluorescent back light(s).
You can see what they look like here:
eBay-Toshiba inverter boards
The first characters of your model number - L305, are the most important, the others detail items such as CPU, hard drive, etc.
Dec 01, 2010 | Toshiba Satellite L305-S5933 Notebook
Toshiba satellite l305-s5933 have up at startup with blck screen background and tioshiba writing and the centre. asks to press F2 to go to setup or f12 to go to boot manager but when you press nothing...
Sounds like a corrupt bios to me. Download the latest for your particular laptop from the Tosh site and create a bootable usb with the relevant flash file. Restart and then try to access the bios again from F2
Mar 15, 2010 | Toshiba Satellite L305-S5933 Notebook
How do I remove my hard drive from this Toshiba
no problem with the wiring. just pull it and will come off. not a big deal as toshiba says.
Jan 21, 2010 | Toshiba Satellite L305-S5875 Notebook
Need to hard restore Toshiba Satellite L305-S5945 to its orginal state. How do I do that? The Satellite L305-S5945 is the correct product info not the L305-S5941. It is a laptop.
For the very original state you'll need the Toshiba discs. Insert the one that's labeled as needed to restore your system and boot to it. At one point you'll be promtped to delete the existing partition (this wipes your data) and then you can reinstall Windows on the empty partition. If yo udo not have the Toshiba discs, you can still load Windows using a Windows installation disc, but you will likely need to find the missing drivers for your laptop, so don't go this route unless you are comfortable with it.
Nov 09, 2009 | Toshiba Satellite L305-S5941 Laptop
How to Replace hard drive for Toshiba Satellite L305-S5875
This useful link will help you...
Jun 24, 2009 | Toshiba Satellite L305-S5875 Notebook
I have a Toshiba Satellite A70 laptop.
you can try the memory try one stick at a time. also try the laptop with as little components as possible.
remove the dvd drive, hard drive and wifi card and see if it will boot.
then put each one back in at a time and try it to find the culprit
Apr 24, 2009 | Toshiba Satellite A70-S249 Notebook
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
