Question about Garmin GPS
The car charger that fits on the back of my garmin i have to hold it in with my fingers to get it to connect what can i do to fix this?
  • sheltonplane Dec 05, 2008
    Ok the model number is 19A259741 garmin 200 nuvi thats all i know about it. When i put the charger onto the back of it the charger will not fit snug and i have to hold it on there to get a result. The garmin works fine but only if i hold the charger to the back of the garmin. I noticed the little clip i put the charger on in the back moves up and down slightly. What can i do?
  • Garmin Master
  • 2,130 Answers
I need more info.... what is your Garmin model number? Nuvi 2xx? Nuvi 3xx, 6xx? Is this the GPS cradle or the plug that's giving you the trouble? let me know and I'll have a solution for you.
- Jim
SHARCNET-USA
Posted on Dec 05, 2008
  • SHARCNET-USA
    SHARCNET-USA Dec 05, 2008
    The problem you are having is a loose Mini-USB jack. The contacts of this jack have come loose from the board. The jack either needs to be replaced or resoldered. To see a picture of what you are describing, please click on this link:
    http://www.sharc.net/nuvi_charger_repair...
    Look at figure #1. In this picture, the jack has completely fallen off. In time, yours unfortunately will too. If your unit is still under warranty, please contact Garmin at www.garmin.com and they will replace your unit.
    - Jim
My garmin was working and the other day i plug it in the car charger in and now my garmin will not work while it is on the charger. If I take it off the charger it will work but not on the charger. what...
Does it show a picture of a satnav connected to a computer when plugged into the car charger? Sometimes this happens because the charger plug is not fully pushed into the back of the satnav even though it feels like it is. Pushing it in further may solve the problem.
Jul 14, 2011 | Garmin nuvi 250W GPS Receiver
Plugged in my Garmin 205 this morning and all the screen will display is the GARMIN logo. How do I get it repaired?
hold your thamb finger at right/bottom cornner of LCD screen, then plug in car charger. unit will reset to factory mode. try it.
Mar 18, 2011 | Garmin nuvi 205W GPS Receiver
How do you troubleshoot if the garmin gps suddenly just don't want to turn on even if it is plugged on the charger?
Try a "Master Reset" on your StreetPilot c550:
Power the StreetPilot off (ensure that it is not connected to external power)
Touch-and-hold your finger in the lower right corner of the Touchscreen...
Power the StreetPilot on...
Continue to hold your finger there until "Erase all user date?" appears...
Remover finger from the Touchscreen...
Touch "Yes"
If this doesn't work check to see if your item is still under warranty. If not I can provide you with a place that fixes gps' relatively inexpensively. Hope this helps.
Mar 09, 2011 | Garmin StreetPilot c550 GPS Receiver
My just purchased yesterday will not turn on this morning. should I return it , I have tired the power button x 10 sec. and doing the finger at the lower right screen still nothing .
Try charging it first. It takes 4 hours to charge fully if connected to a car charger or a mains charger. It takes 8 hours connected to a computer with the USB cable. If it's charged and still will not turn on bring it back and get it replaced.
Feb 21, 2011 | Garmin nuvi 1300 Car GPS Receiver
When I plug the gps into the charger a computer picture shows up and I can't get it on any other screen. What's the matter?
Did you recently purchase that charger?
This usually happens when the charger is not compatible with the unit. or you could be using a non-Garmin charger. There are some "store-brand" chargers that work well, and some do not. Store brand Charger are made to be Universal. To fit multiple devices and maximize profits. You want a Garmin Specific Charger, and here is the logic why...
The reason behind it:
1. The Garmin USB Cable that you connect to your computer has a special 4-pin configuration telling the GPS that is is connected to a computer. This is the configuration most "generic" chargers use to maximize device compatibility.
2. The Garmin Car Charger has a different pin configuration with 2 less pins, giving it only positive ( + ) and Negative ( - ) to charge the GPS.
When the GPS receives the 4 pin, which is also found in a "Motorola" Cell phone charger, it will automatically sense that it is connected to a computer.
Long winded, but I wanted to explain why. Simple fix, Just go get a new charger and make sure it's Garmin compatible.
Jan 04, 2011 | Garmin nuvi 255W GPS Receiver
Garmin won't come on
plug it in to the wall charger or car charger for about 4 hours, then slide and hold power button for up to 15 seconds till it starts.
if that fails, unplug the nuvi then press and hold the lower right hand corner of the screen until you see the message " Do you really want to erase all user data?" remove your finger from the screen and select YES. (this will erase all your saved data) this should reset your nuvi to the factory settings.
use the web updater to update your nuvi once you get it started again.
you can get it HERE
let me know if you need further help.
bill
Sep 05, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
When i plug my car charger to my GPS it turns it to PC mode and im not able to use my GPS while its charging.
Here is a nice trick to use the Garmin while charging with a USB cord or a wall charger: with the Garmin unplugged keep your finger on the battery icon for about 10 seconds until the diagnostic screen comes up. Then connect the USB cord and press EXIT; the Garmin will reboot and you will be able to use it normally.
Jan 22, 2009 | Garmin nuvi 205 GPS Receiver
Garmin charger problems
19A259741 is the serial number. The model number should be to the left of that on the decal label. It's sounds like you have a Nuvi 2xx series.
The mini-USB jack is loose. Either is has come loose from the board or the connections within the jack are loose from everyday wear and tear (use).
If the jack is loose from the board and it needs to be resoldered or replaced if the jack is worn out.
- Jim
SHARCNET-USA
Dec 05, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
