Question about LG WM1814CW Front Load Washer
What does IE on the display mean? - LG WM1814CW Front Load Washer
  • 1,543 Answers
IE means inlet error. Most likely the washer took too long to fill, due to a plugged screen where the hose attaches to the inlet water valve. Frozen water line would do it also. Or a bad water valve.
Posted on Dec 05, 2008
    Problem Solver:
  • 16 Answers
IE is a water inlet error, if the correct water level is not reached within a specific amount of time, you will get this error. Check and make sure your water tap is open and isn't frozen. Check your water pressure as well.
Posted on Dec 07, 2008
Daewoo washing machine when turned on does one rotation of drum then displays L _t then displays E1 after 10 secs. Then stops on that.
ie code can mean no water entering machine check water valves and filter or could be solenoid valve in machine faulty
Dec 10, 2016 | Daewoo Washing Machines
Can not connect to Wi-Fi
Do you mean for the Amazon Kindle store? Provided your wi-fi signal is good, which you can check by trying it with a smartphone etc, the Paperwhite should connect itself to Amazon automatically when in range. If not, try these things
- verify the Pw (Paperwhite) is registered properly (ie Amazon knows it)
http://www.amazon.com/gp/help/customer/display.html?nodeId=201235720
- check your network is listed already on the Pw
http://www.amazon.com/gp/help/customer/display.html/ref=help_search_1-1?ie=UTF8&nodeId=201241790&qid=1457135457&sr=1-1
- generally speaking
http://www.amazon.com/gp/help/customer/display.html?nodeId=201852540
If you are talking about wi-fi and using the Pw internet brower, forget that, it is not worth the effort, the Pw browser is such a non-intuitive dog of a thing.
Mar 04, 2016 | Amazon Kindle Paperwhite
IE on screen what does that mean?
The codes these displays usually show that are hard to trouble shoot are:
88888 - This means the unit has suffered from dirty power or power surges and should be unplugged and plugged back in about 60 seconds later. This should reset the unit.
OF- Means the unit is in a Cooling OFF Mode, This is a power saving feature used by Retail locations. Some call it a DEMO mode.
PC-ER - unfortunately means your unit needs service.
IE - is a tough one, I would like to see it first hand but if everything is working correctly might possibly be a display error and it should be saying ICE - I have not come across this one in person.
Aug 06, 2013 | Samsung RF4287HA
Washer displays IE. What does that mean?
is this an Lg washer ie error code is an water inlet error either low water pressure , kinked fill hoses or bad water valve ....
Jan 23, 2011 | Washing Machines
What does Ie mean on display
I believe that it says "IE ERROR". Could this be right? If so it's a 'water input error'. You have to check for a kink or clog to the water hose running to your machine.
Hope this helps.
Jan 12, 2011 | LG Washing Machines
Can you buy an plug for this modle to pluge in at home.
European Players use 220-240V (50hz) while american ones use 110-115V 60hz
You need a step up VAC source.
Alternatively most (ie LG, Daewoo, Goodman etc) use a vatiable PSU. ie 100-250V which means you can plug it in direct. Just check the markings on your player.
Also keep in mind Uk, EU Africa use PAL, while the USA use NTSC. make sure your TV can display PAL too.
Feb 28, 2010 | Emerson Televison & Video
Trying to go to gmail.com but i keep getting ie cannot display we
don't mean to be rude but are you trying gmail.com or googlemail.com? I have two email accounts with google mail but only the full google will work, not a g.
Sep 23, 2009 | Yahoo Mail
No longer outputs audio from cable box. Code "PCM 2.0" on display after setting volume
PCM just means the type of audio it is. The 2 means stereo! Does the unit have a choice of audio outputs IE digital or linear?
Sep 06, 2009 | Audio Players & Recorders
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
LG WM1814CW Front Load Washer Logo
377 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
